Got my truck running this evening with the Wehrli S475 over stock kit. Took it for a couple test drives to get some heat in it so I could top off the coolant tank. Everything was fine on these trips, probably 10-15 minutes of driving. Went for a little bit longer test drive, got on it a little bit (maybe 50% throttle), heard a big air rush like a boot letting go, then no boost. Took the air filter off and found the compressor wheel rubbing the housing. Any idea what could cause this? I prelubed the turbo, oil feed line is hot so I know there's oil flowing through.
I was recording at the time, uploading video right now. Should be ready in a few minutes.
