New personal best 11.35 @ 122
13,751
821
Reaction time has no bearing on ET. The ET timer doesn't start until the staging beams are cleared.
red1977
Nov 15, 2010
786
47
Ogden Utah
Thanks man but you were on the right track going for a bigger pump. Don't get me wrong, I'm shocked the little pump 1) hasn't failed and 2) supplied enough fuel to get me this far with the stock fuel pickup lol. I need bigger and you should go bigger too or add a second 100 pump for the other CP3
Alright thanks for the advise, I'm going to be putting dual pumps with 45% overs on a stock bottom end truck with 400k lol and a 473 single.
hondarider552
Getting faster
May 28, 2008
10,627
Arizona
Congrats brother! Let me know when you want to run the balloons and we can set a date. I have my own prep so traction wont be a issue :woott:
We lost .5 coming from AZ to ABQ in Logan's cummins FYI, same setup/tune ;)
I will be at sea level on Sunday though :D
DBUSHLB7
Team DMAX
Mar 9, 2012
2,789
Albuquerque, NM
Are you telling me I'm a lock for a 10 in PHX without any changes lol? I'm there. Will January work? That Alabama trip ruins my chances for Nov
chevyburnout1
Fixing it till it breaks
Aug 25, 2008
2,368
Berthoud, CO
Thanks Dustin maybe one of these days we can race together!
Next year! New converter and turbos dialed in! I'll totally road trip. I have a PPE160 and it just touches 0psi on a 2600µs pulse tune with a stock pickup and dual pumps. Still haven't lost rail pressure so far.
Hot COCOAL
May the farce be with you
Jun 9, 2012
4,433
My wife would love it if we sold it lol. Yep I'm pretty set on racing in PHX this winter. Just needs to happen and then I can use Brian's slicks.
Yep pacific NW is awesome! Plenty of oxygen up there! Thanks for rubbing it in lol jk
I don't have one but it's working off the stock pickup too. The data logs are showing rail drop :(
I'd like to see what you'd do with a set of slicks in some good DA...
Wasn't trying to rub it in at all, I'd take some sunshine over DA any day, lol
But knowing what DA I've got in my local area now maybe y'all can understand why my truck is such a runner
And ya know Damian, I just recently found that my AD2 quick connect line made it all the way up to the factory hard lines up in the engine bay...I was deleting my hard lines so from there I hooked it into a FASS PLB-1212 1/2" quick disconnect fitting that's barbed on the opposite end, and I put together a 1/2" brass tee that had the 1/8"NPT port already provided for the in-line pressure gauge and fitted some Gates 1/2" fuel line from the PLB-1212 barb to the tee, reduced the 1/2" tee down and finished my supply line with Gate hose to the PPE CP3 fitting...the whole setup cost me about $50!
Just food for thought!
You can see the gauge in this pic...now I know I'm supplying the CP3 with 11psi
:thumb:
DBUSHLB7
Team DMAX
Mar 9, 2012
2,789
Albuquerque, NM
:thumb:
It looks good!
DBUSHLB7
Team DMAX
Mar 9, 2012
2,789
Albuquerque, NM
How much boost does it make? What PW and timing does it see? Truck back halves the quarter very well. Nice run.
2800us on 60 overs. Boost is in the low 60 range I believe but honestly after some torque steer off the line my adrenaline had me watching the finish line I didn't look at the boost needle I wish I would have looked. Timing is somewhere close to 30 Steve said. Thanks for the kind words, I'm hungrier than ever for another shot at this.
