New High Capacity trim springs
S Phinney
4,008
Quncy, Fl
I have to give Ole Mike props on his springs. Trans shifted great before but shifts better now. Adaptive learning is improved as well. Great job Mike with these advances in Allison technology.
Jan 28, 2015
961
Ohio
Are these something you can get to with just dropping the pan? Lol I watched Dmitri build
Mine but there were a few springs in there.
N2BRK
2,059
391
drop the pan, remove and separate the valve body. Swap springs. Reassemble.
Awenta
4,090
CT
If Dmitri built it you will not need them. His top of the line trans don't need them
Or those silly aftermarket clutches.
On the other hand, buy them to have for the inevitable rebuild
nsolimini
Sep 18, 2011
72
Lakeland, FL
Well, I will be ordering a complete set.
Question though, the 2 trim springs I am assuming go were the two go from the Transgo Jr. Which 3 of the 6 valves are the shift valves? If I remember are they the three that are held in with a plate? Do the three springs have a specific valve to install in or can they go in any of the 3 shift valves?
Jakemax04
Jun 28, 2013
127
The 3 shifts springs came with my purchase of mikes pressure spring when I ordered From dirty hooker. Looks like I just need the springs for the trim valves
