i have a 1/2 ton ss awd truck , im putting down about 600-650 awhp to the ground , i have a pretty aggresiive stall , its rated at 3k but will flash to 4k
running a centrifigal vortech blower on a built 6.0( now a 6.1, 6.0 bored .030 over) forged everything. 9.25 cr with about 16 psi.
running the stock motor (10.1-1 cr) with about 10 psi i could cut 1.6x 60 fts everytime. hardly any wheel spin. it ran 12 flats and one 11.9@ 109.9
now with my new set up i run 12.0's at about 112 but traction is almost gone in first gear. i need some advice on what i can do with the little 1/2 ton.
i will also be spraying a 150 shot of juice to it in 2nd and third gear once i find traction.
i recently did this
strapped the front end using limit straps for an offroad truck, it will limit the travel of th efront suspension on a launch so my frotn wont spin as much hopefully.
i was hoping to find an e locker from eaton but i got stuck with the weenie 8.25 front diff with no aftermarket what so ever, id like to swap to a 3/4 ton unit but it would involbe major bucks and work.
im looking for ideas to help me hook . i also have a set of 305/45/18 drag radials for 18x9.5 rims coming soon.
just getting them hot is hard without being able to do a awd burnout properly heating them.
looking forward to using some techinques you all have,
thanks to pat for informing me about this site.
i recently did this
