LB7: new guy want power(no money)
Durascrap02
Aug 7, 2010
300
Yankton, SD
you like that picture, i didnt have 1 of my truck yet so i just put mine on there, we got a 4440 on the farm for bailing, and a 4010 my favorite anyways thanks
wdino73
735
55
Versailles, Ky
Oh I had a bunch of money then I bought a truck
Now I don't have any money an I'm down on my luck
But when I turn on the key, my heart is filled with glee
And when the black smoke starts to roll, I know I've reached my goal
So when u see me coming down the street u can say there he goes an there he went
I'll be running from my wife, cause she's found out I spent the money for the rent.
LOLOL
Durascrap02
Aug 7, 2010
300
Yankton, SD
i gotta question for you, typically whats the first thing people do to increase power and at what point do you have to bump the tranny up?
TeaBagger2006
Im a Garrett Nut Swinger
May 11, 2008
3,123
15
Bis ND
For you lb7 chumps a boost increase valve from ppe (best bang for the buck)
an exhaust and a tuner....peolpe say that after 90 hp increase your tranny starts to fail
but I think it's more just depends how you beat on it
sparepartsracing
spareparts offroad&fab
Mar 17, 2010
773
yeah i dont believe that 90 rule ive been on the 135 tune for a while beating it, even with my tire selection she can still rock to 130mph
Durascrap02
Aug 7, 2010
300
Yankton, SD
whats the boost increase valve is that like the adjustable deal that goes on the waste gate vacum hose or something else and is the efi live a tuner or is that something on top of everything else
Big Block 88
Multiple choice muscle
Nov 3, 2008
4,665
Kansas when I am home
EFI is a tuner but it is a custom tuning device. You hook the handheld to your truck and pull the stock tuning out of your truck ecm and then you put it on you lap top and mess and twist some numbers around (be sure you know what you are doing or know someone who does anyone here is williing to help you learn) and your truck can go from 1 hp increase to 300 horse increase depends on how bad you wanna be
Durascrap02
Aug 7, 2010
300
Yankton, SD
intake kit?
does any1 have a suggestion for an intake i was thinkin the afe stage 2 cold air type cx 54-10782 i cant tell if it uses the maf or not though
MadMaxx61
Devilmaxx
Oct 13, 2008
5,458
Windsor, Ont, Canada
http://www.pacificp.com/store/index.php?main_page=product_info&cPath=2_7&products_id=43
"Product Description:
The Boost Increase Valve, is designed for 01-04 Duramax LB7 diesel engines, increases boost pressure from 18-20 PSI to 28-30 PSI for additional horsepower and reduces EGT (exghaust gas tempuatures). Additional fueling may be needed to gain higher boost levels."
Like Jordan said EFI Live is more of a custom tuning software and a handheld you can get tunes made from "Tuners" we have a few here and they are good a what they do. You can also have as many tunes as you want you just load a new one in. Also you can get a DSP2 or DSP5 switch that you have have more than one tune loaded in to the ECM at a time and change with a twist of the knob.
Durascrap02
Aug 7, 2010
300
Yankton, SD
ok gotcha i just read up on that ppe boost valve that sounds like a good deal, i could use my old hyper tech tuner but someone was tellin me that it was good that i stopped using it, otherwise i gotta figure out what tuner i want to try and get
