LMM: New Danville 68MM Stg2R Review
TowU4Free
#SecretSquirrel
Aug 27, 2011
469
5
My 3794 randomly did the reduced engine power about 3 or 4 times over the course of 7 months . It wasn't enough to bother me that bad it was a rare occurrence . It usually was part throttle under boost conditions
TowU4Free
#SecretSquirrel
Aug 27, 2011
469
5
The 68MM stg2r hasn't had the issue and was created and tested by Mark to get rid of that issue on the lmm and lmls
TowU4Free
#SecretSquirrel
Aug 27, 2011
469
5
Glowshit elite.. I have them because they have the "tattle tale" function allowing me to go back and see what my max reading were. Boost/Pyro/Fuel psi
Thunderwood
Apr 5, 2014
66
Warrensburg, MO / North AR
I seen that in the video! I really like your gauges and just your truck in general! Gonna have to look into a set of those... It is hard to look at your gauges when the skinny pedal is at about the front tire and you're SLIDEWAYS in the middle highway, so the "tattle tale" function would be great!
andy-stevenson
Jul 7, 2013
838
Now that you've had it longer? Thoughts on comparison between this and the 3794? Spool up? Power? Whistle?
TowU4Free
#SecretSquirrel
Aug 27, 2011
469
5
Spoolup: identical between the two
Power: the 68 'feels' stronger up top than the 3794 by a small amount and it hits harder no doubt !
Whistle: it is louder than the 3794 HOWEVER the whistle isn't as crisp as the 3794 you have the whistle plus a little bit of "sshhhhh" added in (stock turbo sound vacuum cleaner ) due to the prototype vanes. But it's ear piercing literally at high idle.
Bonestock
1,358
Worland Wy
Damn it I was trying to stay somewhat stock. I have stock turbo, engine, fuel but reading this is going to net me a stage 2 charger and fuel upgrades. I had the fleece cheetah 63 billet with 45% sticks and an exergy 10mm pump. This setup ripped no doubt but it also ripped the needle off the pyrometer. If this setup while handle egts better it sounds like a no brainer. Has anyone tried dual pumps or 10mm stroker with 45% or larger sticks? Wondering how it handles egts with more fuel?
TowU4Free
#SecretSquirrel
Aug 27, 2011
469
5
If someone wants to hook me up with some larger injectors and or a stroker pump I'd be glad to test :)
TowU4Free
#SecretSquirrel
Aug 27, 2011
469
5
My first post tells the difference between the 2 chargers on stock fuel. :thumb:
