New Banks Power plats at the PRI show
724
is the super turbo
a sequential setup like cats"sequential" or how toyata ran their "sequential" twins
as pe looking that engine picture agaiin..
it looks liek a super turbo compound not sequential..
air goes in the supercharger then into the turbo. that correct?
sqeuential both woul have seperat air inlets..
MadMaxx61
Devilmaxx
Oct 13, 2008
5,458
Windsor, Ont, Canada
is not compound and sequential the same thing.
Parallel is what you are thinking of I think...
Can we get a pic of the other side of the "BANKS SEQUENTIAL SUPER-TURBO DIESEL"
WolfLMM
Making Chips
Nov 21, 2006
4,005
AL
I think SC feed into turbos. SC provides instant off idle boost, as rpm increases the sc fades off and the turbos come on. Seems like the SC would restrict the turbos at high rpm??
And X2 we need a pic of the other side.
724
no compound and sqeuential are two completely diferent setups except one thing.. they are both setup ro flow a shit tune of air over a wide rpm band
the both use a small charger to light the big charger...
compound runs them in series has only 1 air inlet.. this see high air flow and high boost numbers
squential is parrellel but function in series. has 2 air inlets. this see low boost numbers and high air flow numbers... squential is setup as a "parrellel" but are two different sized turbos one big and one small.
toyata/porchese use the sequential setup on their high reving engines for driveablilty...
as for picture... its not clear out is is acutally setup.
wolf.. it would make sense for the SC to be running lowed... and turbo for the top end... question is how are they blending the two.
