These trucks are pieces of crap! I feel bad, I'll give you 100 bucks for the truck so you don't have to deal with it anymore
can you crack an injector line loose and see if you have fuel coming out when cranking?
Don't do it at all, in my opinion.dont be anywhere near the engine when you do thiscan you crack an injector line loose and see if you have fuel coming out when cranking?
The high pressure fuel system on these trucks is nothing like the old ones. Cracking a line can cause all sorts of problems, and if you get near it, you can get diesel injected straight through your skin, which can be nasty.
A much better (and safer) way to check the high-pressure fuel system operation is to read the rail pressure sensor through the diagnostic port. Many tuners can do this, including EFI Live.
