New and slightly confused
Dieselspullhorses
May 8, 2013
13
Polk city fl
Hey all have a 2006 6.6 and I have no idea if it is lb7 lly etc and have no idea how to tell. Currently it is siting not running as it ran fine then when I shut it off it wouldn't start. Turns over but no start. Changed fuel filter and was just told it needs a new fuel pressure regulator. Any thoughts
dirty_max
815
eureka il
did you prime it? if you did then try pumping the primer button while someone else cranks it. unless you have a lift pump, then it would be a waste of time
blue8135
Diesel Addict
Dec 12, 2010
106
East Texas
When you primed it, did the primer get real hard? May have a slight leak and pulling air. Seals in the fuel filter head tend to go south.
blue8135
Diesel Addict
Dec 12, 2010
106
East Texas
Ok. I would block the egr and do pcv reroute. Clean the MAF. Use only donaldson air filter. EFI Live should help too. When I bought mine w/55k, drove it about 4.5hrs home. Got crappy fuel mileage. Bought a tuner, because I had no idea about EFI Live, and the higher settings yielded better MPGs.
Lbz1989
May 6, 2013
By chance did you or someone else maybe put unleaded gas in? When I bought my truck the dealer I bought it from didn't know it was a diesel and put gas in it. I didn't know he did it either and drove it about an hour to the house and then went to start it back up and nothing. Lets just say the dealer wasn't to happy when he found out he had to shell out a couple grand to fix his mistake
