Need help
blackdirtymax
Apr 15, 2010
825
augusta, ga
which one is the primary and which is the secondary?:eek:
i assume the primary is the one with the pedal, which is what it is spliced into
dark blue wire that pins out at location 5
02bigstrokin
Sep 9, 2008
882
why not just take it off for this weekend? then get ahold of ben when you can and get it taken care of. ive pulled my truck without any lockup box. just asking
blackdirtymax
Apr 15, 2010
825
augusta, ga
It hits the rev limiter the whole way down the track , while doing that it's defueling. Doesn't make for a decent pull.
Built motor , duel fuelers , 60's overs , gtx4202r
juddski88
Freedom Diesel
Jul 1, 2008
4,657
120
Chesterfield, Mass.
Trey, got your message, phone died...anyways, i have his old controller that was once in Kyles truck. Not the new style. He installed it for me. I tried calling him to relay the message but got no answer as well.
blackdirtymax
Apr 15, 2010
825
augusta, ga
Thanks for the help man . Hope I can get it figured out
13,736
806
Have you checked that wire you tap into the APP wire to see if it is feeding voltage back into the pedal circuit? Maybe something you could fix with a simple diode?
juddski88
Freedom Diesel
Jul 1, 2008
4,657
120
Chesterfield, Mass.
Yea, it may be a bad board, who knows...he has had a few of them...I think he's got a dozen or so out there by now, so 2 exact similar issues out of that many seems to be interesting.
blackdirtymax
Apr 15, 2010
825
augusta, ga
Yeah I wondered about that , haven't checked yet . Got some ideas on a good way to check it ?
TrentNell
Finally underway !!!!!
Jul 7, 2008
7,543
slc tuah
I was thinking the same thing Josh about checking for voltage or signal the box could be putting out , also what type of connector are you using to tap into it ? I have seen the "t" tap style connectors cut though almost all of the strands of copper and scew voltage reading before .
blackdirtymax
Apr 15, 2010
825
augusta, ga
Yeah hope so , I wonder why it freaks out more in 4 wheel drive and not so much in 2
13,736
806
I would start by unplugging the wire, turning the key on, and checking for voltage at the wire coming from the controller.
juddski88
Freedom Diesel
Jul 1, 2008
4,657
120
Chesterfield, Mass.
The way the boards operate, at least without asking ben first to confirm, is that they are supposed to sense resistence, and if the resistance is not exactly what is programmed into the box, then obviously it won't work properly...as he and I have learned, resistance is a finicky thing, and it is a function of voltage.
blackdirtymax
Apr 15, 2010
825
augusta, ga
At first I just used the connector he had supplied with the wires ( already crimped on one side ) but then I wondered if it was just getting a bad connection so I pulled all that apart and then soldered the wire to the other , still same issues
TrentNell
Jul 7, 2008
7,543
slc tuah
In 4WD the TCM has a lot lower WOT threshold ( like 40-50% ) then it goes to the WOT patterns for a lot of stuff , may or may not even be related but could be .
blackdirtymax
Apr 15, 2010
825
augusta, ga
Makes sense Trent , it will come and go while in 2 wheel drive but as soon as you put it in 4 , your not going anywhere . No pedal what so ever
