was directed to this forum and was told this is the best one with the real experts.
before i registered i could read the other forums but now i cant see them while logged in so i assume this is a spam filter of some kind or need a amount of posts etc. so hope posting this is ok here.
my truck is a 01 lb7 bone stock with 135 k and stock i mean the same size tires on it that it came with. only things done have been routine service and i change the fuel filter every 5k with oil service.
and has a problem. ..po093 code after no rpm higher than 2000 pulling a load.
only time it does this is pulling a load but it does not do it every time.
just once in a while.
new fuel filter & new fuel pressure regulator did not correct the issue after a dealer said that was it.
same thing , once in a while wile pulling will do this and throw the code.
i tried a different dealer but after the 130 $ diag they said i had bad injectors but could not tell my why they were bad and then i told them every oil change i have no fuel in the oil ........and my friends shop that does little basic service has a scanner and the balance and return rates were near perfect ( from reading online what they should be ) and then the service guy said the fuel injection pump was bad after he went and talked to someone else after i gave him the info.
i realy cant find anyone in my area that knows d-max so i hope someone can help me save money and repair this without the guessing game and throwing expensive parts at it.
sorry for a long post but hope i gave enough info for my issue.
thanks in advance.
thanks in advance.
