He's running a ii motor in his trucks isn't he?
Definitely not.
HSP did all the accessories/turbos, not sure who did the motor, but probably someone new since it's actually lasting more than 5 dyno pulls.
Industrial does run D's Allison though.
Definitely not.
Anyone?What did he even hit?
Sent from my D5803 using Tapatalk
I don't think dmitri ran on the dyno that II laid down 2300. In his faceyspace rantings he said he wouldn't run there because he knew that dyno would lie and he tried convincing II not to run there also or somethin like that. He has been consistently putting down around 1860 on fuel though.Anyone?
I promise a 3.0 truck motor in a race truck would run faster than tens!!! You cant lie on the race track. With the weight of the truck and trap speed it will tell you the HP. It doesn't matter if you spin or not the trap speed doesn't lie. Now ET is a different story, then truck setup means everything. Spiking a dyno means nothing if that's all it can do. What's the point if its not a useable power?
I guess I don't see why everybody hates dyno numbers? Just because you don't have a fast track time doesn't mean you don't make power. Setup means more on the track than power. How many 3.0 pullers do you think would run the tens? I doubt many if any. But I would bet they all have dyno numbers that should put them there. Congrats to ii. That is one hell of an accomplishment. Those numbers didn't come from doing the same thing everybody else did. They stepped it up and did something nobody else has. I think that is awesome. That is what the sport is about.
I'm just a newb, so can you explain how trap speed and weight will give you HP regardless if you spin the tires or not? What if you blow the tires off 1/2 way through 60' because your tires are junk? Wouldn't you show a higher trap speed with DR's hooking all the way down the track therefore calculating a higher HP number? Like I said I'm just a newb, so if I'm wrong just let me know how it works. Thanks.
Every single one of them.
