Your talking about the "delaminated clutches" issue that was years and years ago. ATS is way more advanced now and no its not BS. ATS will in fact warrenty clutches, i have seen it done personaly. As for your situation with them i was not there and cannot comment on it. I had a bad valve body one time and instead of tearing the VB off and giving me a new one they dropped the whole trans, stuffed a new one in and sent me on my way.
Again, talking about old clutches from years ago.
Like i said, It was installed correctly. I was there and witnessed it. I even double checked it a second time. So what does that leave for a conclusion? ATS will be in contact with guy and yes ATS is going to re-bearing the whole bottom end and fix any other issues
Again, like i already stated. I just wanted to know what Suncoast was doing for him (if there was part failure it needs to be warrentied)and look at what happens....This forum turns it into a ATS attack. I dont want to argue over this dumb BS anymore!
Again
Why don't you worry about your truck that doeasn't work and let me worry about the posters problem. If you had the knowledge to answer tech questions you would have built your own engine and trans; but you didn't cause you can't. Instead you act like the ATS ACLU. Get back to us when you can drive the truckaround the block without being followed by a flatbed.
