My Build Has Started!
9,903
149
B.C.
Stock. I had the nozzles extrude honed to 40 over by Kennemetal. I wouldn't recommend going this route.
9,903
149
B.C.
Now to decide whose injectors to run and what size.
All I know for sure is I need it to be able to cold weather start and run without popping and farting and no blue haze at idle.
So definitely not bigger than what I have.
ikeG
Oughta Know Better
Apr 19, 2011
2,465
147
Western PA
www.facebook.com
Sounds to me like you're blaming the problems on the nozzles instead of the junk injectors. Nozzles I'm sure could be reused on a new set of injectors. Unless you have a good reason they may be bad?
9,903
149
B.C.
Because they were fine before I did the nozzles for one.
But it could be a combo of both. I have extended crank times when it's cold, including multiple attempts to get it started and when it does it smokes and pops and farts like a cold 6.5 like it has waaayy to much fuel in some and missing in others. (glow plugs are new and working). Then at idle it smokes blue quite badly.
It could be bad ball and seats, sticking nozzle needles or poor needle seats. As they replaced one needle when they returned my nozzles, I'm guessing this is the common problem.
9,903
149
B.C.
Either way they are coming out and testing and inspection will confirm the problem.
Burn Down
Sep 14, 2008
7,092
Boise Idaho
I had two Kerma TDI nozzles go bad that caused high return rates but had perfect balance rates. They leaked where the nozzle face mates to the injector bore.
9,903
149
B.C.
Just thought about this. I never changed the mm3 for idle areas after the bigger injectors were put in. Could this be my problem? I did lower my mA so rail pressure is on point now but when I tried to change mm3 at idle a little all I did was make it start and idle worse.:confused:
Any thoughts? Should I try tuning at idle some more to see if this fixes the smoke and balance?
Lb7_Katie
Lb7 Duramax
Sep 8, 2013
851
31
on my old set up I purchased new injectors and had them honed out and not even a year later they were garbage and I had to purchase brand new injectors..im glad this time around I went with exergy.
