LB7: My buddies 01 Rod threw the block!!!
JustinD
Plow Truck
Nov 21, 2008
2,067
42
Tiverton Rhode Island
My buddy was driving his truck home last night, he just rolled into the throttle and the truck made some funny noises and stalled, he coasted to the side of the road and tried to restart and it wasn't having it. Looked around, smelled oil, and found a good sized hole in front of the drivers side motor mount, you can see right inside!!!!!!!!! Now he on the hunt for an LB7.
Is this common? He has been running a pretty big tune for about 50k. The truck has 170k on it now.
TrentNell
Finally underway !!!!!
Jul 7, 2008
7,543
slc tuah
Def not common , but if you bend a rod and keep running it , the rod can only bend so much before the piston skirt hits the crank . Just my best guess ?
duratothemax
<--- slippery roads
Aug 28, 2006
7,139
10
Wyoming
yeah it happend to me! I was running aftermarket rods though.
not common with stock rods, they are pretty forgiving in that they can bend a fair amount and give you a lot of warning (smoke, rough idle, low compression) before they actually break.
JustinD
Plow Truck
Nov 21, 2008
2,067
42
He found an LB7, it is out of a 3500 that supposedly needed injectors, the company just bought a junkyard motor for it and put this one in the corner, he can get it for free, it was smoking at an idle, I told him to replace all the injectors and run it. It was never abused, hopefully it needing injectors didn't hurt the motor????
JustinD
Plow Truck
Nov 21, 2008
2,067
42
What is the best way to get the motor out? Take the nose off?? Or can it be done with it on? We are going to attack this job this week. Any tips or tricks??
5,911
Takin the nose off will make life much easier. i dont think you could get it out otherwise. heck its jsut a few more bolts to remove the front clip anyhow lol.
05maxlly
need used tires
Jan 27, 2008
194
powhatan, va
just pulled mine last week (lly) all i can say is take ur time its not too bad should be about 5 hrs to get it out at least it will come out with the turbo on it its just a little tight
