My 06 ccsb build/bull thread
yellowchevy
1,928
82
Louisburg, KS for now
You have to point the rear half down and pound the old seal out. Clean up the mating surface to make sure everything is good.
Then stand the rear half on bench/table with the end pointing up so you can install the new seal. I make special tool for doing this so I wouldn't damage the seal and make my life easier, haha :thumb:. It takes me about 5 - 10 minutes with that tool.
I hope that makes cents.
If you have access to dry ice you could put the seal in that so it shrink down a little. That way it should install easier. I would do this as a last resort though.
If you want any specs on that tool or want to borrow it let me know.
Yellowchevy
omaha123
yeapp
May 10, 2014
86
Nebraska
Yellowchevy
okay. so pound It out from the inside of the case? Then the new one goes in from the outside.
I'm assuming the bushing comes out the tail section as well
omaha123
yeapp
May 10, 2014
86
Nebraska
Well got the t case back together and in the truck.
Also got my ppe sleeves in, and my all seasons brace.
Tomorrow, gonna put shafts and fluids In. Then go get an alignment and new tires put on
omaha123
yeapp
May 10, 2014
86
Nebraska
Well didn't have time for the alignment or tires yet.
But I did do the rear axle seal today.
Gonna lower my tbars tomorrow. The previous owner has em cranked.
Should I just drop em til the cvs are level?
Sent from my SCH-I545 using Tapatalk
07bluelbz
Work Hard & Play Harder
Sep 6, 2009
742
Beaumont,Texas
All depends on stance you want. If they are level and the rear is stock height, you will have a hell of a rake. If you put 3" drop shackles on the back, then you can adjust the front until the truck sits level. The have some angle from the factory though.
omaha123
yeapp
May 10, 2014
86
Nebraska
Don't really mind the looks just want healthy angles for launching. I'm assuming dead level should be good.
Dozerboy
4,926
508
TX of course
two days ago i drove her 80 miles to check out some recently hail damaged vehicles, got home, went back out started her, backed down the driveway and she died. would just crank on end. so after numerous calls to ne-max ,one rebuilt filter housing, and some more help from ne-max we got her running again.
Found the kit at NAPA! Rebuilding it.
They sell a o ring kit for the filter head at NAPA. Was if list as a Dmax filter head rebuild kit or what?
I need a new one for the hand pump after my rebuild its leaking now I think...
omaha123
yeapp
May 10, 2014
86
Nebraska
Yeah I asked em for a filter head rebuild kit.
and I had to talk em through what it was but they had em
omaha123
yeapp
May 10, 2014
86
Nebraska
Not much going on this week.
Axle seal is leaking again.
I'm sick of it so I'm sending it to a shop.
Trying to source some guages, then tuning.
omaha123
yeapp
May 10, 2014
86
Nebraska
Been a while since I've done anything, just been saving.
Gonna build the trans and do tunes here soon, just debating to build it myself or have it built.
c20elephant
C20ELEPHANT
Apr 25, 2013
2,065
Phoenix, Arizona
omaha123, when I flipped the trans cooler on mine I noticed the panel below the cooler was not attached and was more than likely flipping up and blocking air flow while cruising down the highway. Pop the grill loose and check yours.....:woott:
56taskforce
1,089
70
I noticed you were thinking about doing your own Allison transmission build and I am preparing to do mine as well. Here is what I have found for helpful information.
The two books to the far left IMHO are the best the two to the right are what comes most recommended from the masses on the forum. I have one more manual on its way it is the actual GM service manual the second from the right is Allison's service manual.
omaha123
yeapp
May 10, 2014
86
Nebraska
Definetly am gonna pick up those books.
Trans build sorta got pushed to back burner. As I just bought a new to me bass boat...
omaha123
yeapp
May 10, 2014
86
Nebraska
Next week will be a transgo jr. maggy 4 inch kit, finally i have a normal exhaust!
And some cab lights the gf picked me up for my birthday. Should be fun!
Big Block 88
Multiple choice muscle
Nov 3, 2008
4,665
Kansas when I am home
Looks good.
On the leaky axle seals I have had them on my last lbz and my lb7, and it just kept happening, I finally took them to a shop and both had bent axle tubes that didn't allow the seal to seal. Gm warrantied my lbz and we junk yarded the lb7 with a low mile axle.
