Maximized Performance Inc I believe...
Just curious; what torque converter have you found to be the best for the Twin Turbo set up? What is the optimal stall and coupling for running twins? This might have a Dumb A$$ card to it as well. But thought I would ask.... Also if you are saying that the twins are pushing 45-55psi boost and not running head studs etc, does this mean GM made some adjustments, to handle this boost pressure.
MCRAT stated earlier that at around 45psi the truck is not tractible. Is this with the twins... or can you explain this more.. not quite understanding what is meant by this.
My experience with TC's:
The trouble is getting past 2000rpm when staging. It's dependant on tuning more than charger.
For racing, no converter on the market will stall at less than 3000 when you get past the 2000rpm barrier. But some are "tighter" than others. For engines with good power at 2500 (Tune Only to 2.6" charger) a tight converter is quicker, like the Suncoast 1057. But when you go up to 3.0" and larger, looser is going to be quicker.
For twins using the stock charger, a SC 1057 will most likely be the quickest choice, since they can make good power down low. But if they are "big twins", I'd start with a looser converter. Casper runs a Mike L. converter and it spools well with a 3.2" charger (1.5x sixties) and has no problem with the PPE Bonneville twins (3.0+3.6").
The 1057 in my truck has no stall that I've found, too loose IMO on my truck. I really like the 1054 for the standard set of MPI twins.
Nathan and I tested a converter that stalled right at 2200 with his set of twins on his LMM. Felt very good and launched very hard. It is back at the manufacture getting loosened up a hair.
