im not having different people do differen things, he doing the machining and im assembling it, thats all the people that are touching it.
Why should i run his rods over carrillos?? I havent heard any feedback on his?
extra oiling is never bad, with that x beam rod. i would let curtis what is your plans and let him give you suggestions on what is needed
I will be running DPR rods when mine lets up. PM Jeff (stingpuller) I believe he is running them.
Look back at Pats thread on his crowers in the engine that let go. The only flaw he found with them was that there was premature wear on the wrist pin bushings. I believe that ther are some threads on DP with other rods having wrist pin wear issues. To me the extra oil galley in the DPR rods is an awsome addition. Correct me if i am wrong but in stock form the only way the wristpins get oil is from the oil jets and in these high HP engines the extra oiling is welcome.
Just FYI theres like $100 difference from comp and socal cam, Id go with the custom when/if you do
i could be misremembering but i think the carrillos can be special ordered to have an oiling feature too.
Not saying it is the case or not but the argument against the oil passages is it removes material that some think *may* reduce the strength of the rod in that area. Just something to think about.
Pros and cons to everything. Guess you just have to figure which one you think would be a more likely reason for failure later on. I personally think the oiling (or lack of) would become a bigger problem than strength of the rod but that is purely a WAG on my part.
I've subscribed to this one. Good thread!
Why? How many people running standard ARP head studs are lifting heads?
actually its between a 4-500$ diffrence
Youre wrong. I love how you just pop around once a week or so to join in on someone else talking shit.
Custom Ground Duramax Camshafts $915.00 Includes Drive Key Option.Drive Key Option $150.00
Off The Shelf Comp Cams Duramax Cams $625.00
$140 difference for a comparable item.
Curtis quoted me $2850 for the xbeam rods and $150 for the drilled bearings 3 months ago, idk what the price is now.
YES- curtis halverson(dpr) designed them, and howard's rods mfg them. anyways what do you think of the a1/ats h11 headstuds? you think they will hold up better than the standard arp headstuds?X-Beam? You mean Howard's Rods?
