I have turned vats off in stock tune. Still no change. However, when I realtime log it still says vtd fuel enabled. Going to try tech 2 in a few min.
http://www.duramaxdiesels.com/forum/showthread.php?t=2035&highlight=vats
Or try shutting vats off in tune, or set the key off to like 10 seconds between reset and use link above. If you leave the vats stock in the tune, you need to follow the link close and it takes about 30 minutes.
THANK GOD!!!!!!!!!!!!!!!!!!!!!!!!!!! I still don't understand how it fired up those few times, and you were actually able to drive it to get fuel!! Things that make ya go Hmmmm!!!!
