Making a 4L80 Live
Oct 16, 2008
948
12
Idaho
Long story short. Say a guy wanted to put a 4L80 behind a Dmax with 600ish hp in a street/strip car that weighs 2800ish lbs. What would be the recommended parts list for making it survive? Let's assume it hooks so we can't rely on traction issues to make it live. I'm assuming converter/shift kit but what else would the trans gurus recommend?
Mike L.
15,681
232
Fullerton CA
Keep it out of 4th.
SmokeShow
6,818
Lawrenceburg, KY
I'd talk to JoshH... He's had as much success as anyone with a 4L80/85 behind a hot dmax and at twice that weight. I believe he tried Jake and ended up with different valve body for line lock and his own build. I'd definitely pick his brain if I were you. :thumb:
Oct 16, 2008
948
12
Idaho
So a good converter/manual valve body shift kit, minimizing burnouts and keeping it out of 4th under power should make it live a somewhat lengthy life? That sounds good enough to me. I don't mind killing one occasionally but I'd rather not have to yank a trans every time I drop the hammer.
coker6303
Keep Calm and Chive On!!
Aug 6, 2009
2,484
40
Houston, TX
Talk to JoshH. He has been through his in the van a few times, had a couple of issues on the initial build from someone else but nailed it after starting fresh himself.
hondarider552
Getting faster
May 28, 2008
10,627
Arizona
overdrive planetary is the weak link. Keep the burnouts to a minimum.
Josh does burnouts every race..?
buddy of mine has a Jake's 80E with just under 900 torque in his 4500lb 6.0 1/2 ton, been fine for over a year now, it's not a diesel, but it does make uber amount of torque for a stock engine LQ4
AUSDMAX
AUSSIE DURAMAX FANATIC
Mar 21, 2013
97
i say talk to joshH aswell iv seen he has had a few issues with jake's and has resolved them now he would be the guy to talk to in regards to a diesel 4l80
AUSDMAX
Mar 21, 2013
97
diesel having so much torque id run a 36 element super drum at minimum even if in the tear down its already running the 34 element drum id still do it. TC wise an allison based triple plate modded for an 80e would be the go
Mike L.
15,681
232
Fullerton CA
The O/D sprag will fail.
AUSDMAX
Mar 21, 2013
97
this is correct mike they are very week but as i think you said keep it out of OD and keep the burnout short and sweet they live a while i build all my own. i believe ck performance was in the process of making up a new OD section to eliminate this failure point i could be wrong though
550
that line used to be O/D or O/R clutch packs...
AFAIK no one makes a sprag for the O/D.. its a roller clutch OEM
yet the NX dmax mustang broke the IIRC intermediate shaft then went full built from coan
josh nor i have had issues with 4th gear
dave GN dmax clone never got enough traction to really hurt anything...
good bit of the 6-7 sec cars on the hot rod drag week where running 4l85s
13,714
776
This is going from memory from events that happened 1-1.5 years ago, so some of it may not be in exactly the correct sequence of events.
When I was getting ready to build the transmission in the dumpster, I went to Jake's and bought all the parts he recommended as I was going to build it myself. After thinking it over some, I decided I would be more comfortable having someone with experience working on the 4L80 build it instead since I had heard so much about the transmission not being able to hold up behind a Duramax. I took it to Jake, and he put it together.
The first time out with it was the Texas NHRDA race. The thing was not working well at all. Come to find out, Jake had swapped the pan which caused the dipstick to read incorrectly (in the van, the dipstick bottoms out in the pan to set the depth). Once this was fixed, it was much better.
I took it to another race a couple of weeks later, and it shifted pretty good but not what I would call perfect. You could see in the logs where some of the shifts were very drawn out. He pulled it apart and replaced some clutches. I think at this point he also took the converter to have it cut apart and inspected. He found that the converter was a stock converter with a billet triple disk cover (which I knew). He blamed that for most of the problems I was having.
Anyway, he put it back together and I went and picked it up and took it straight to the track. I made maybe half a dozen passes, and I could tell the trans was slipping already. It also was skipping over second. I took it back to Jake and they found a busted intermediate sprag and some more burnt clutches.
This is about how it went for about 5-6 months. I would take the whole van to Jake, it would be there for about a month. I'd pick it up and go straight to the track and take it right back to Jake. Over the time period this was happening, we had Jake install one of his trans brakes, and we took the converter back to Chris at CircleD to have him lower the stall. He ended up reworking it and tightened it way up using some Dodge diesel converter parts.
The last time I went to pick up the van from Jake, the trans brake wasn't holding. I tested it out before I loaded it on the trailer and as soon as I started to build boost, it would roll right through it. I told Jake and he said it was because the pressure wasn't coming up enough and that I needed to cut the power wire to the pressure force motor. I took him at his word and loaded it up. I went to the track that weekend and I couldn't do anything to get the trans brake to hold. I was having to stage and launch with the foot brake and the parking brake. Not what you would call and optimum scenario. The next Monday, I called Jake. He said to bring it to him and he would fix it. My dad took it up there on Tuesday with the promise that Jake would have it fixed by lunch time. Lunch time came and went, and at 5 Jake said he needed to keep it overnight but would finish it the next day. The days went by, and I got no call from Jake saying it was ready. On Monday, I called the shop several times trying to get in touch with Jake about when we would get it back. I needed it because the NHRDA World Finals were coming up that weekend or the next, I don't remember for sure, but they were close. I never got a call back from him. At 9:30 that night my dad called me up very upset that we didn't have the van back yet from Jake. He was the one who was paying for it all, and he felt like he was getting jerked around. I told him to calm down, and I would call Jake on his cell phone. I called Jake at about 10 that evening as soon as I got off the phone with Dad. He answered not so politely. We talked for a couple of minutes. I called dad and told him he could go get the van the next day, dad then called Jake and they talked for a few minutes. I got a text from Jake at about 2 am saying the trans brake was working.
The whole time we had the transmission from Jake, the data logs showed the shifts were not very crisp. It just kind of slid into gear. Over the off season, I talked with dad, and we decided we were going to go a different route on the transmission. I called up Rossler and ordered a new valve body with his trans brake in it. I went through it and replaced all the clutch packs and installed the VB from Rossler. When I opened it up, I found every clutch pack was burnt (some worse than others but none of them were reusable). I also found every pan bolt hole in the case was stripped, one of the valve body bolt holes was stripped, and the OD clutch bolt hole was stripped.
The first time out on the track, the thing shifted better than it ever had. It was as close to perfect as any transmission I'd ever driven. I was for once very happy with how it was working. It wasn't my imagination either. We picked up 2 tenths over the fastest pass we ever had with Jake's transmission.
As far as breakage, the only hard part failure I have had was an intermediate sprag (34 element). The rest of the carnage (as far as I know) has all been clutches. Here's a list of what is in my transmission:
Billet input
Billet forward hub
Billet intermediate
Rossler TB VB
CircleD triple disk converter
Alto Kryptonite frictions with Kolene steels in the overdrive clutch
Alto Red Eagle Power Pack in the forward clutch
Borg Warner Hi Energy frictions with stock steels in the direct clutch
Borg Warner Hi Energy frictions with stock steels in the intermediate clutch
I do burnouts on every pass, but I have it setup to start in 2nd. I also do use overdrive, but I launch it with the shifter in 3rd to bring on the over running clutch in the OD section to take some of the stress off the roller clutch in overdrive, but I have launched in overdrive a bunch of times without breaking anything.
Mike L.
15,681
232
Fullerton CA
I built the trans in Davids GN.
