MAF rescale
dieseladdiction23
Nov 13, 2012
152
Celina, Tx
Hey guys, Im just about finished with my s475/stock install, and im wondering if im going to have to have the MAF sensor rescaled. The pipe its in now is rougly 4 3/4 inches ID. If so, does anybody know what I need to change the numbers to? I would like to save the $50 bucks for a tune change if possible. Thanks
Fingers
Village Idiot
1,715
86
White Oak, PA
OEM => 4" or 12.566 sqin
New => 4.75" or 17.721 sqin
1.41 times bigger so air parcel will be moving 71% slower through the tube.
In the MAF table, multiply the grams/sec rate by 1.41
dieseladdiction23
Nov 13, 2012
152
Celina, Tx
So if these are my numbers, do I just multiply by 1.41 on all of them. Max is 66.14 so the last couple will be maxed is that ok. Because I drove it today and it is very laggy. Thanks guys
0.00
0.91
1.65
2.27
2.84
3.42
4.03
4.72
5.50
6.40
7.43
8.61
9.94
11.42
13.23
14.88
16.86
19.00
21.32
23.80
26.46
29.29
32.31
35.53
38.94
42.56
46.41
50.48
54.81
59.40
64.27
66.00
66.00
Fingers
Village Idiot
1,715
86
White Oak, PA
Yes, multiply by 1.41 and "adjust" the values that exceed the table's max. 66.00 in your case is the max.
dracing70
SH--- GETTING EXPENSIVE!
Jun 12, 2007
1,210
45
mantua, oh
I have a question. How did u establish the 17.721 quantity. I understand everything else except how u came up with the new base number ???
PACougar
2,105
41
El Dorado Hills, Ca
That's the area of a 4.75" circle. π × r2 You simply calculate the area of the original intake pipe and then compare it to the area of the new pipe.
S Phinney
4,008
Quncy, Fl
Using this math formula does not get MAF back in specs. Even though your truck may not be laggy take a reading of MAF at idle and WOT and you will see where you are. I adjust using percent differences of the readings not pipe size differences. I have tried the pipe difference before too.
Sent from my XT1080 using Tapatalk 2
blue8135
Diesel Addict
Dec 12, 2010
106
East Texas
I'm still confused. By my math, I can get the 12.566=(4*3.1416), but by the same formula 4.75*3.1416 does not equal the 17.721.
dieseladdiction23
Nov 13, 2012
152
Celina, Tx
Yea I'm gonna have to try something different, drove it to work today and it was kinda sputtering. So I did some more adjusting and now it has lag again.
S Phinney
4,008
Quncy, Fl
The formula would be radius squared times 3.14. That hives you the 17.71. Just read your MAF at idle and see what you have before making any adjustments.
SickLL7Crenshaw
Billy The Kid
Mar 10, 2013
1,088
Mexico
You sure it's your maf causing all of this? because there are more tables you have to revise after you put your kit on, not just the maf flow rate table.
dracing70
Jun 12, 2007
1,210
45
mantua, oh
This is how i base my changes also. I have had very positive results with percentage changes. that is why I was curious about how the new number was established. I never thought to use the formula for cylinder area. But its good to know thanks for the responses.
