MAF rescale
dieseladdiction23
Nov 13, 2012
152
Celina, Tx
Ok, so my maf is still tuned a little higher than stock but right now it's reading 28 g/s at idle, and wot it maxed out at 390 g/s, idk if that's just what my edge insight maxes out at or not, I don't have my laptop with me to check it that way. So basically I need to figure out what it will take to make it idle at 40 g/s and increase it across the board???
THEFERMANATOR
LEGALLY INSANE
Feb 16, 2009
3,890
ZEPHYRHILLS, FL
For LB7 I think mine is around 28-30 but my idle speed is at 600. I think at a 680 idle it should be around 32-35 for an LB7, and the VVT trucks are up around 38-40. I know a completely stock LLY is only about 28, but a stock LBZ is around 42.
dieseladdiction23
Nov 13, 2012
152
Celina, Tx
Yea it's bouncing around at idle anywhere from 27-30 but mainly around 28. But I just need to figure out what it will take to get rid of the lag
dieseladdiction23
Nov 13, 2012
152
Celina, Tx
40% put it around 39.x rougly, I started back over from stock which was 25 g/s at idle and increased it by 60%. so now its idling at 40 g/s. So im going to test it out tomorrow. If that don't work im just going to let Rob handle it lol
S Phinney
4,008
Quncy, Fl
Also check WOT readings. Should see 400-500. Mostly close to 500. If that checks out your are good and it will not be MAF related.
Sent from my XT1080 using Tapatalk 2
