lowered truck pics
David Burton
Nov 29, 2017
Las Vegas, NV
Let me post a couple of dropped Tahoes here
And here's where I've taken them if you want pictures from different angles
https://www.carid.com/gallery/chevy/tahoe/
anthonyking166
Feb 25, 2016
12
30
Does anyone have the t bolts out and the overload spring removed? Just curious to see how it looks
Sent from my SM-G955U using Tapatalk
1TRIKHD
Country boy Limo.
Sep 15, 2015
1,705
408
P.N.W
I like it! Now you said something about the center pin? What's up with that
You will need to get a shorter one. The one that's in there now isn't threaded all the way up to the top of the alignment pin. I just went to ave hardware and got a grade 8 bolt that was shorter and a nut to go with it.
Deny
Oct 30, 2016
23
Hi does any one know what is thr most positive ofset one can get for a 2500 4x4 lowered 3 5 thanks Denis
Deny
Oct 30, 2016
23
Novak i plan on getting 20 the reason i want lots of positive on the wheels is because i am building a 55 chevy on a dmax frame and the front need to go in as much as i can. the 2500 was lowered 3 in the front and 5 in the back this brought the front wheels out. i would need something like plus 80 been looking but cant seem to find anything with big positive offset. any help would be appreciated
thanks Denis
OregonDMAX
NOT IN OREGON, NO DURAMAX
Apr 28, 2013
3,964
Goodyear, AZ
Most stock wheels are positive offset most aftermarket wheels are negative. You aren't really going to find more than a +24 positive
Novak
SQUIRREL TRYN TO GET A NUT
Jun 15, 2015
990
Cloud 9, IDAHO
So ultimately you want them sucked in like a rat rod? The reason I asked wheel size is because the calipers and brake are 16” until 07.5’ and then they moved to 17”
The stock wheel size (on WT/LT 07.5’) was a 17” +10 offset
I’m running my winter wheels and they are 17” +18 offset and I had to reroute my wheel speed sensor lines because the gap between the wheel and the spindle was that tight something like 3/8”
Keep in mind that what you’ll need to clear is your spindle at anything over +20 so I would measure your spindle and see how big of a wheel you need to go over that.
Novak
Jun 15, 2015
990
Cloud 9, IDAHO
Brock is right though on finding anything more than +24
That’s gonna be a custom built set if it’s even possible
Where did you figure +80?
