lowered truck pics
moparkxracer
2,309
33
Out and about
1500 grille, bumper cover and side corners. There are little black fillet strips that pop on top of the corner pieces. 6.00 from gmparts direct.
picture.php
picture.php
Lb7_Katie
Lb7 Duramax
Sep 8, 2013
851
31
Who's running DJM 3/5 and what shocks are you using? Gonna order mine. Just curious what everyone is using
pizza pig
I Like to Party
Feb 13, 2012
266
CT
I am running a setup that I found to work well, and probably would for the 3/5. modified KYB's.
Give me a bit to dig up part numbers. Same travel as stock, but 2 inches shorter in the front and rear. Rides nicely with the torsion bolts out and 2 in shackles in the rear.
OregonDMAX
NOT IN OREGON, NO DURAMAX
Apr 28, 2013
3,964
Goodyear, AZ
Using rancho 9000xl shocks. All I could find was 2" lower than stock, which works just fine but I couldn't go much lower than a 3/5
emailed rancho, they don't like lowered trucks apparently. They said they don't intend on the 9000 adjustable to be meant for the street/track even though they do work. So they aren't making as my shorter ones.
clrussell
pro-procrastinator
Sep 23, 2013
5,955
422
I spent about an hour on the phone with rancho one day figuring out lowering shocks.
Rs9000 adjustable part number 999267 rear shock. 14.5" collapsed, 22.5 extended.
Front I think a front halfton rs9000 was perfect match. Or im sure Sean can get you the part number from his fronts.
TROJAN366
Gold Rush
Jan 13, 2012
2,474
MASS
Shackles, no overloads and bolts most of the way out.
pizza pig
I Like to Party
Feb 13, 2012
266
CT
I used KYB Monomax shocks
Part numbers
565101 and 565103 (bolt on)
The 565101 required me to press out the lower slotted bushing and replace with a 5/8" Poly sleeve bushing and new inner metal sleeves. Works like a charm. The shocks ride well and the truck feels sportier dropped. Stiff, but comfortable. Launches well too ;) :thumb:
c20elephant
C20ELEPHANT
Apr 25, 2013
2,065
Phoenix, Arizona
Then what good are they if they're no good for either the street/track..
booxr800
Boo
Sep 13, 2009
157
Central Michigan
Alright guys it about time for me to get new tires. I am thinking 285/55R20. How many have had them on their lowered truck and how much drop did you have? Right now I have my keys backed out and shackles and hangers in the rear set at about 4" drop. Once I install the lca's it will be 3/5 drop
Drrrty
Dec 26, 2015
90
Also running 305/50/20 on pretty much the same height as moparkxracer.
Sooo damn ( . )( . ) we still gotta meet up sometime man. I wanna check this thing out in person I absolutely love it.
