lowered truck pics
c20elephant
C20ELEPHANT
Apr 25, 2013
2,065
Phoenix, Arizona
Just installed my 2" belltech shackles...not to impressed. It only lowered 1.25" kinda depressing considering the bs I just put up with to get the dang things in there
McGaughys front leaf drop hangers, remove some overload leafs, never ending ....:D
Doesn't Belltech make some 3" drop hangers?
408.Luke
Joined the DARKSIDE
Sep 19, 2009
432
Houston
Yes sir but not like stupid tight I made em effin tight once she was down
Sent from my DROID RAZR using Tapatalk
I would lift the truck up, loosen all 4 bolts, set it on the ground and then tighten them and see where it's at. You might be surprised the difference it makes
minerigger
2,660
Casper, WY
Before and after. You be the judge.
minerigger
2,660
Casper, WY
I'll give her a shot tomorrow. I can tell it went down when I look at where the overload would contact that bump dealio but it doesn't seem like that much.
That being said I need to pull the cognito uca off and throw the stock set back on and maybe get djm hanger/shackle
kansascav24
Feb 24, 2014
15
Pennsylvania
2" drop shackle with the overload spring pulled out. I think it looks just right! I also just put the wheels/tires on last night.
mvetting
Nov 24, 2013
Finally took some pictures of mine even though shes filthy. But shackles have been installed overload removed along with new shocks and keys dropped till cvs are slightly negative. Still needs the bumper and grille painted but that will happen next week.. Sits perfectly level with 1/2 tank of fuel.
guessing you are running 20x10s in -12mm offset. I went back and forth on running those wheels with my 420s but decided to keep my 20x9 +18mm offset to not rub. So do you have any issues with rubbing. I have the large fender mod on my truck and easily clear now with the front about an inch lower than stock. Awesome looking truck by the way!
Sent from my XT901 using Tapatalk
20miller12
Aug 27, 2014
24
thanks im really considering doing air all the way around and ditching 4wd so i can lay it out when parked ill post some more pics up later
TROJAN366
Gold Rush
Jan 13, 2012
2,474
MASS
Just a few recent pics of the truck. Nothing crazy, just 3" shackles out back and dropped the T bars to match.
zf>allison
you never had your car.
Apr 30, 2013
3,394
elsberry mo
picture.php
picture.php
Not on my full drop in the rear. Got one more hole I'm gonna go to. 285\60\17 toyo proxes on lmm wheels with old style caps. Roll pan soon, repaint bumper soon
crazycrew
Let's Start A Riot
Oct 3, 2009
1,230
S. Louisiana
Not REALLY lowered, but 2" shackles in rear. Front is cranked a little to match
Soon to be removing overload, and another leaf, and I'll let the front down to match
05smoker
I'm officially done!
Mar 30, 2007
2,379
Lebanon, OH
3" drop shackles and overloads removed. Working on swapping my current airbag setup now.
