Glad I have a 1 ton srw. Its only getting 3" shackles and lower the front down a tad....at least for now
Sent from my DROID RAZR using Tapatalk
Gotcha. I'm wantin to use the coilovers 408.Lukes been helping develop but not sure how much actual drop they'll give. This is pretty low i know but with the DJM thin trans cross-member i dont think it would be an issue. 1" taller LCA shock mounts would raise it up a hair more
he used stock LCA's, with the DJM LCA's and the coilovers you would be way too low.
I understand but i was talking about DJM's trans crossmember. they make a low profile one thats flush with the bottom of our frames where as the factory crossmember hangs down about 3" lower than the frame. http://www.summitracing.com/parts/djm-cm2699/overview/model/silverado-2500-hd it would be helpful if u encountered speed bumps often or or have less than perfect roads. fabing one out of the stock crossmember doesnt look like it would be that hard. just cut the height off needed weld it to some plate steel and drill your holes :thumb:he used stock LCA's, with the DJM LCA's and the coilovers you would be way too low.
The DJM LCA's re-clock the torsion bar, so they don't have any affect on ride height with coilovers.
Now on the matter of the air bag brackets, would a posting a CAD drawling with all the specs be good enough for everyone? Thats something i could easily do and post
thanks for the pics:thumb:. in your opinion would a thin crossmember be worth the coin for a little more clearance?
Thanks guys. i didnt think there would be a strength problem with it but for the price of buyin DJMs i think making one from the stock crossmember and a piece of plate steel would be just as strong and cheaper to
