Losing coolant.
9,905
151
The fan and engine compartment turbulents could also throw it around.
That cover is not too bad-just 2 bolts IIRC. I think you can get at it if you remove the inner fender.
Cougar281
1,830
268
St Louis, MO
I've been slowly loosing coolant as well; I found what appears to be a 1" wide coolant trace down the side of the block on the passenger side in the back, and it appears to originate at the headgasket :(
maxaholic
1,876
40
Central, Texas
do i need to take loose the starter or up pipes and manifold to get to it.
ive bout got half the mind to just pull the m-f'er and go from there and hell maybe even do a budget build.
13,751
821
I don't think you need to pull either. Should be lower than the up pipe and higher than and further back than the starter. I hope by budget you don't mean inexpensive... :rofl:
9,905
151
You may have to pull the downpipe and possibly the up-pipe as well to see it.
13,751
821
It is at the back of the block on the side. I'll see if I can find a pic for you.
13,751
821
In this picture from Henry's build thread you can see it directly behind the bellows of the passenger's side up pipe. Like Dale said, the down pipe may be in the way of it when it is in place.
maxaholic
1,876
40
Central, Texas
damn Josh why did you have to be right. But im glad you were cause now I can fix it and start driving my truck again.
But here is my thinking. Why did it blow out that gasket. Could maybe headgaskets or some other un foreseen problem.
Also, does anybody by chance know that p/n.
Thanks guys for all the help too.
13,751
821
At least it's something simple. I'm not sure on the part number. You should be able to find it at the dealer. Shouldn't be very expensive. When you put it back on, I'd recommend using some RTV on both sides of the gasket. The same gasket is used on the opposite side of the motor to seal the coolant after it goes through the oil cooler, and it leaked on my truck the first time I put it back together. Used some GM engine sealer RTV, and it didn't leak a drop after that.
maxaholic
1,876
40
Central, Texas
Efn piece of sh!t dealer here didn't have the gasket. They said maybe have it in monday, but they would call me when it does. Which usually means it could take longer if never. So do yall think using some permatex(sp) rtv would cause any problems. Or should I just pray for the dealer to hopefully get the gasket in.
13,751
821
Just smear a little RTV on the gasket you have and see what happens.
