Losing coolant.
maxaholic
1,876
40
Central, Texas
I don't have a clue where I'm losing it from yet. My first thought was the water pump but after finally getting it in the shop and looking it is coming off the back off the motor somewhere. Any help would be appreciated.
maxaholic
1,876
40
Central, Texas
egr cooler looks good. No leaks off of it. Any other ideas. i've checked all around the turbo also and can see no visible signs of coolant. But where on the turbo are the coolant lines.
S Phinney
4,008
Quncy, Fl
There is a pipe that runs coolant along the passenger side that attaches to the front side of the block that has a tendency to break at the weld of the bracket. It would be hard to notice but it happens a lot. Check out this coolant pipe.
motohed
dirty payback
Apr 15, 2008
486
escondido, ca
welcome to the coolant leak club! at least you can see that yours is leaking. i cant find any trace on my truck. ive been super slammed with work though so i haven't been able to really look into it.
the coolant line goes into the turbo from the passanger side of the valve covers into the bottom of the turbo. it returns out of the drivers side via a little black hose attached to a cone looking metal piece under your metal tube going from the thermostat to the upper radiator.
maxaholic
1,876
40
Central, Texas
alright ive about lost it been looking at the motor and taking stuff off for about 2hrs and i'm just tired of looking at it.
13,751
821
Is it running down from up high or what? There's a plate on the right side of the flywheel housing that blocks off the coolant passage in there. It has a metal gasket that may be leaking.
13,751
821
I'm just trying to think of things over there that could leak. I've never seen or heard of one leaking, but you never know.
13,751
821
I don't think it's that big of a deal. It's just forward of the bellhousing on the right side of the motor. I'm not sure how hard it is to get to with the engine in the truck, but I doubt it's that bad. Should be a little above where the starter bolts in.
maxaholic
1,876
40
Central, Texas
You might be on to something cause ive noticed a little on the starter. But what gets me is how did it get onto the centerlink. Maybe ran down the oil pan?
13,751
821
I don't know. I would almost guess it is coming from somewhere in the front, maybe that coolant pipe that someone mentioned breaking at the welded bracket, and blowing to the back of the motor, but you said it is leaking from the back when it is pressurized.
