In 4low should the converter lock automatically? I understand the unlock function for a sled puller but it should lock on it's own.
Thats him. Truck is a monster. Currently has a 2,6 cover on it but he has a legit 480 on its way.
Awesome! my brother is running a s467.7 which is what Ahale had been running but if that doesnt cut it it will probably get a set of 366/48? twins.
Yes sir.ok here is a random question, and forgive my ignorance if im totally off base here, i just know nothing about the lockup boxes
say im cruising down the highway at like 65-68 mph in 6th, could i tap the unlock on the box to help spool the charger a bit to pass a car? then tap lock and lock it back up to keep cruising?
I just bought one of Ben's lock boxes off of 07Dirty, still in the mail. But anyways I was reading off his website about the 30sec duty cycle... what is everyone's experience with this? Can you just keep it force locked on the highway, or does the thermal protection just kick it onto auto again?
I use auto most of the time as well. It does tend to lock up a little early at partial throttle on the street occasionally though so I usually dont have the box "turned on" unless I plan on doing something noteworthy.Lol ive actually jsut been emailing back and forth with Ben on this today. the duty cycle is 15sec in the new boxes. No you can not do that as the box will kill the function after 15sec. it doesnt do much for you anyhow as the converter should be locking into 5th and up pretty early at highway speeds.
if your worried about it under WOT, use auto mode. then it will lock right up as soon as you go 100% throttle.
right now he and i are trying to see why when i click auto mode, the converter locks right in at any throttle position like im going WOT. i have a feeling the wiring for 01-02 at the tps is a bit different
I think you wouldnt need to force lock on the highway, since thats the convert SHOULD be locked cruising the highway.
There fun on the street from a 20mph roll
mine doesn't do that but,,,the green light will go off for no reason and as soon as I hit the brakes,it comes back on.
