Most know that I run my 07.5 LMM as a hotshot.. Fully load trailer weighs ~28,000lbs. Got the truck with 97k on it been towing 7,000-28,000lb trailer. For vast majority if those miles.
Currently has efi live, lift pump GT4088R with a T3 .85 waste gated housing and stock trans.. Dynos right around 400/800 at the tires. An extra 50-75hp would be nice but not needed.. Stock cp3 fueling is as far as I go..
Coming home from a Dallas run truck put a hole in #8 piston..
Current plan is/was mahle finger 17.5:1 pistons bore in balance.. Apon tear down I have found something that I don't like/not sure about... Which might lead to rods being replaced.
Oil sample said there was high levels of cooper and iron.
So pictures..
Best rod bearing #7
Worst rod bearing #4
Bootom side of mains
Topside of mains
Perp hole on #8
#8 cylinder
#2 rod
Random progress shot
Skirt wear #8
#2,4,6,8 skirt wear.
So pictures..
Best rod bearing #7
Topside of mains
Perp hole on #8
#8 cylinder
#2 rod
Skirt wear #8
