Broken Crank on LMM. Dealer Sayz F*$k You It was Chipped. Lookin for new motor. found one with out an ecm will my LMM ecm run the LMM without the ecm?
when i done the dpf delete i went with a ppe hot plus 2 and 4 in mbrp exhaust. tried it in the 150 horse setting once but was to erratic didnt make the trans feel good. at the time of faliure it was in 40 horse and driving in a snow storm 40 mph knocked a couple times and started missin. oil pressure was good. pulled off the road and called a wrecker. motor is now out of truck looking for new LMM:thumb:
thats scary! A lot of lmms running aroud with a lot more added power than that. ow many miles?
Fight it and you will not win. Last 10 codes from flashs most match up with gm's codes.
X2. Unfortunately your screwed.
How much damage is done to the engine? Can you get away with an allign bore and just a crank? May be cheaper than buying a new engine. An LBZ crank will work for you as well as an LBZ block but the top end needs to be LMM-different injectors.
