LMM Fubar.
9,905
151
No Russ. It needs to be 10 different CVN's that are GM stock. And there aren't 10 out there so your f'd.
JD Dave
In way over my head
May 19, 2008
2,388
Caledon, Ontario
X2. Unfortunately your screwed.
How much damage is done to the engine? Can you get away with an allign bore and just a crank? May be cheaper than buying a new engine. An LBZ crank will work for you as well as an LBZ block but the top end needs to be LMM-different injectors.
I'm running LBZ injectors in my LMM so I don't think that matters. Can anyone tell me what would need to be changed to put an LBZ in a LMM please.
duratothemax
<--- slippery roads
Aug 28, 2006
7,139
Wyoming
How can they say screw you because it was tuned. I remember seeing that the dealer must prove the modification caused the failure in something called the Magnuson-Moss Warranty Act...best of luck
are we REALLY still debating this and trying to argue that the magnuson-moss act is still a legit argument in todays day and age. :rolleyes:
Catman3406
Jan 24, 2010
23
Utah
could some one cough up an installation procedure for my dumd ass. LOL. the whole front end of the truck is no longer there. well it is its on my shop floor. figure this there was no drain plug in the bottum of the radiator. I ended up cuttung the small 5/8 hose that is molded into the lower radiator hose assm.
