Has anyone had a U0073 "communications bus off" after installing a Duramax with a stand alone harness?
After doing some reading it appears to possibly be a resistance issue because of the missing BCM/GP controller etc.
I measure 120 ohms on the serial bus which is what I would think would be correct, tried loading it down more with 120 ohm resistor, still no love.
EDIT, I found the glow plug controller and plugged it in (I had bypassed the bus on that plug so I could read/write to the ECM) still getting the U0073 code.
I can read/write to the ECM and TCM, the T/C shift control is obviously in communications because when I write to the ECM the front shift motor goes through some cycles
