LMM Cheetha Its Here
duratothemax
<--- slippery roads
Aug 28, 2006
7,139
Wyoming
are the vane sizes and shapes on the LMM cheetah's similar to a powerstrokes?
just curious because that sounds a lot more like a 6.0 than a dmax.
Brayden
Jan 16, 2008
1,170
www.fleeceperformance.com
No... The 6.0 uses the same vane as the LLY.
But the LBZ and LMM have a higher pitched whistle due to the shorter vane and the turbine I use.
It runs way better than a 6.0 I would imagine.
duratothemax
<--- slippery roads
Aug 28, 2006
7,139
Wyoming
:D
I was referring to the exhaust "cackle", not the whistle. The cackle at WOT sounds like a 6.0...I just thought it was interesting because on stock turbo LLY-LMM's they definetly have a different exhaust noise at WOT than a 6.0
Brayden
Jan 16, 2008
1,170
Larry Jewell said the same thing when he got his Cheetah.
Gone is the factory VNT backpressure sound that our trucks were known for.
You hear more motor "cackle" / rumble than a normal Dmax. I attribute it to the backpressure loss and less restrictive exhaust path. The 6.0 guys have a nice set of up pipes and a very nice exhuast housing.. but that's about it. That housing though flows very well and after the 6.0 whistle goes away you really hear the engines on those trucks. I agree.
slowlmm
Mar 2, 2008
2,582
46
so cal
LOL u wana here crackle try a 4094 its the loudest dang thing there is :) yea it feels pretty fast. mph seems to come up quick i would say hp power is lower but mph comes up quicker wich should atribute to quicker times we will see tomarow :) Its alot more fun on the street thoe then the 4094 for sure :D
LarryJewell
Back with his honey :)
Jan 21, 2007
10,152
58
San Angelo
Send Michael what you're running Larry and see how it runs.. I set him up with a fairly conservative fueling tune with higher pressure... If you don't mind ;)
Now Tommy.. I have a set of spare injectors heading my way :D Want to try the same setup as Jerrod? From what I can tell the tips from LMM to LBZ are interchangeable. The hole size is just smaller on LMM.
Then take her down to westech and lay a nice even 700 down ;)
brayden i will try to get some quality video at the track :D. larry i would love to try what you have. i finally got my lift pump put back on and changed the filter. it runs good but i cant seem to get the tires to light up. i havent done any boosted launches yet but i did get the sleeves put on so its coming.
hook up a dsp5 switch and I will fix you up :D
9,906
151
Must be nice to have multilple day options to go to the track. If we miss friday night-we're F'd around here.
Give'r hell Tommy!!
beach_33
704
des moines, IA
yeah that would be nice. the track i am going to friday is only a 1/8th mile. if i miss that i have to drive to cedarfalls which is about 2 hours away. it is a 1/4 mile of water right now though
slowlmm
Mar 2, 2008
2,582
46
so cal
Give'r hell Tommy!!
it just lucked out tht the private track day i sighned up for didnt get cancled :) so we should get some good data and hopefuly some good times. yea track time is limited here famos every two weeks for 1/4 mile track and every thurs for 1/8t mile track :) thanks i will let you guys no how it goes
