This ^While someone cranks over the engine, can you take a pair of pliers and gently squeeze the return line and see if it fires?
Works wonders if it's just air-locked on the return side. Wouldn't be the first time I've had that happen.
I tried pliers by myself, and coke to think of it, that might have been when it hit, I’ll have a buddy come over today and have him apply a little pressure while I crank.While someone cranks over the engine, can you take a pair of pliers and gently squeeze the return line and see if it fires?
Thanks, believe it or not I actually corrected them before even doing any cranking, I just happened to look down while rolling my engine crane over to my truck, and noticed the cam/crank sensors were in the wrong spots. Lol.As someone who's done it before, I always have to suggest verify the crank and cam sensors are in the correct holes. The clocking of the connectors is just slightly different, and will quickly give it away if ya have them reversed. They won't fire if swapped. Besides that, those LML return line back pressure valves is a good place to start.
Pinch it mostly shut with vise grips, start/crank, then remove vise grips.Alright so a 2 man job. I’ll make it happen this week eventually lol.
Quick question. I do not have a 9th injector (Was deleted years ago), that being said, Bank 2, has the 9th injector side, if I were to put the Bank 2 over on Bank 1 (Which was what I just observed), I guess with this heat I overlooked it and put Bank 2 on Bank 1, and Bank 1 on Bank 2, would that cause the crank - no start as well?Pinch it mostly shut with vise grips, start/crank, then remove vise grips.
I do not know, I have never had that occur.Quick question. I do not have a 9th injector (Was deleted years ago), that being said, Bank 2, has the 9th injector side, if I were to put the Bank 2 over on Bank 1 (Which was what I just observed), I guess with this heat I overlooked it and put Bank 2 on Bank 1, and Bank 1 on Bank 2, would that cause the crank - no start as well?
Well ended up getting a new return line because I had noticed a few broken clips. Now the oil pump seems like it lost prime, I primed the oil pump before all of this, and was rocking a steady 30-40+ PSI while cranking, now I’m only building 2.9-3.3 psi of oil pressure… still experiencing crank no start after rebuild…Swapping banks with the return line won’t matter. They are a balanced system, the return regulator is an opened orifice on the injector side. Simple ball and spring regulator.
Trucks will idle with 20psi return. But a new regulator will show 150psi consistent.
You can put shop air into the 9th port to get it to fire, if low retune pressure is the issue.
Can’t seem how to check for that on this Autel scanner I have.Crank/cam signal loss? Have you be able to check for missed cam counts yet?
I would imagine we’d be getting a code for signal lossage. I am however building only what the DFRP is calling for. So I’ve fixed that issue. Lift pump filter gasket was also squashed a little but it is good now. It’s still giving the occasional hit every so often. Oregon fuel injection said if we’ve got smoke we’re close, hell we’ve had smoke since day 1, lol.Can’t seem how to check for that on this Autel scanner I have.
The cam and crank readings are coming back not matching up, took the timing cover off and everything’s in time, it’s CP3 swapped so it’s not injection timing.I wonder on the cam and crank sensor if that would cause the starter to kick in and out?
