2016 LML duramax, cp3 swapped (before rebuild all tuning is for cp3 swap), fass 165, installed Mahle performance pistons and rings, I’ve bled all the air you can possibly think. Maybe there’s more left.
I’m between 430-450psi in all cylinders as well, did a manual compression test after completing the rebuild.
I’ve got fuel at every injector, cracked all lines multiple times to make sure I had fuel and wasn’t just imagining I did. I’ve never had to bleed a LML this much,
It will hit occasionally but nothing more. (Haven’t and won’t be using starting fluid.)
The FPR exceeds my DPFR, EFIlive says around 26k at maximum while cranking, starts at 0, and gradually goes up to desired and then continues to climb to around 25-26kpsi, primed my oil pump prior to putting fuel to the system, with my mechanical gauge I’m pushing around 42psi while cranking. After I got a good pressure, I put the block sensor back in, and reconnected the electronic connector. On my EFIlive I’m reading between 37-48psi on oil pressure. It is fully deleted, as stated all tuning is the same tuning as before the engine blew up, just took it out, bought a new block and stock rebuild kit.
Question: Will not having my radiator, core support, intercooler hooked up allow for the truck to crank but no start?
All ground wires are hooked up, the two on the bottom front side of the block, and the one on the back driver side head.
Any suggestions?
Thanks.
Any suggestions?
Thanks.
