So Adam are you just going to run this durring the summer? How much is you fan running now? Don't you think it's going to kill your mileage for what gain?
Nice to meet you too adam.
Hmmm....underdrive pulleys for the alt and such?
These would be cats ass for fan clutch HYD on/off
You can adapt in the hummer clutch setup. The later models used the same 36x2 mm thread setup and it was a single hydraulic line to the front of the fan via a solenoid tied into the power steering pressure hose. The cost is the big hurdle. Since it's for a hummer, it's not cheap. The only saving grace is it's stock off the shelf parts.
Yeah looks like close to $800.00 for everything but the fan... IDK if the bolt pattern is the same or not.
But like James fan is on constantly for me
Hey guys, I have a 2011 LML I put into a 2011 Yukon 2500 and the fan has never worked properly since day 1 as it wouldn't go on high while the AC was running. Recently I just discovered it is drawing an amp while the truck is off and it drains my battery, after troubleshooting everything I finally unplugged the fan clutch and the current draw went away. So what could cause this in the fan clutch? Also which one would you recommend to replace it with?
