That just seems a little late to lock in at 205 on the freeway I never get that high but in stop and go it would definitely help a ton
Kennedy diesel has a special calibration fan clutch he has made to his spec. Mine seems to kick in around 205-210 running 70, but locks in at redlights, I also found it seems to be much more aggressive coming in once it starts coming on.
https://www.kennedydiesel.com/categoryresults2.cfm?Category=3&SubCategory=209
I'm actually having a solid hub made for the truck strictly for summer time use and towing. Takes just a few min to swap them out
You sure about that?:roflmao:
Have you checked to make sure your cooling stack is clean? You might be surprised how much junk can collect in a radiator over years of driving.
wonder if I could just get a different temp spring,,bet thats all kennedy did.humm
http://www.shivalikbimetals.com/product_details.php?pID=20
Your stats aren't even full open at 205. I posted up screen shots before from the manual, but rear starts at 180, front at 185, bypass closes at 212, but both stats aren't full open until 230 degrees. So at 205 you're only getting maybe half flow through your radiator.
The low temp mishimoto stats are fully open at 190
I'm about to put mishimoto high temps 185/191 in mine, seams fan clutch doesn't want to engage till 190 and I'm pulling ect to 180-185. I was tripping ac hp switch In houston Tuesday sitting at idle...
normally run down the road at 190-195 when it's 80°+ out.
So I bump the TStats 5-10° which cases fan clutch to engage quicker.. and forces more air across the cooling stack especially at low speeds
Be nice to see what happens with that solid fan hub
nope, the "guy" machining it sure is taking forever :rofl:
Ok, now how soon can you make me a billet pulley set?
