LML CP4 Problems
$chultz38
230
5
I just left my local dealership after some parts- They have a truck with 26 yes 26 miles on it with the shaft on the cp4 broken!
ikeG
Oughta Know Better
Apr 19, 2011
2,472
152
Western PA
www.facebook.com
New pumps in the kit come with gear and mounting plate too
Sent from my XT1585 using Tapatalk
coker6365
Coker6303's ***** Daddy
Dec 4, 2011
486
If anyone wants to donate some of those new CP4's in the pump kits, I am always available. :hug:
We are currently working on a kit that will prevent the contaminants from entering the high pressure side. The first prototype worked flawlessly, however, we are trying a new design now that will cut costs drastically for the end user if successful. :thumb:
5,911
coker, is this like the s&s one that will take the "crank lubrication fuel" and put it in the return line and not the high pressure side as well as add the mesh screen?
2,207
What about also doing something to help prevent the failures in the first place? After the failure of the CP4 in my VW I pinned the new pump I put in and also installed a carbide roller
coker6365
Dec 4, 2011
486
The original design was similar but a mesh screen is added and not necessary in the case IMO. The new design will be a slightly different approach if it works correctly.
coker6365
Dec 4, 2011
486
At this time, the main goal is to simply prevent the contamination from spreading if a failure occurs and keep the install time/parts costs to a minimum. Otherwise, I would recommend a CP3 conversion over the prevention since the labor cost is so expensive to swap either pump out.
Did the first failure on the VW have a lift pump, lubricant additive, etc. running through it? I am curious as I believe lubrication and clean fuel goes a long way on these things.
My 3 LML's have a 33% failure rate :roflmao:...
1 - 70k miles and original fuel system. Lift pump from about 10k miles on, deleted at 3000 miles.
2 - 196k miles and original fuel system. Bone stock until 192k miles. Deleted and lift pump at this time.
3 - 165k miles and 2nd fuel system. First system failed at 119k miles if I recall correctly. Deleted and lift pump since 163k miles.
coker6365
Dec 4, 2011
486
BTW, I like the pinned idea to keep the cup from spinning 180 degrees. I don't see how they are able to spin with the spring seat pressure unless they are getting stuck in the head and delay the downward travel on the camshaft but they do it.
2,207
I could totally understand the cost part of it. Labor would be the killer.
VW uses an in tank lift pump that supplies I believe about 14 PSI then the fuel goes to an electric axillary pump that boosts it up to around 75 PSI. This feeds the CP4.
I did run some Diesel Kleen and 2 cycle oil but not as consistently as I would have liked. There is a huge thread over on TDIClub about it and there doesn't seem to be any clear consensus as to wether lubs help, clean fuel or not. Some have even added extra filtration and only fill up at the best stations and still experiencing failures. Its basically not an if but a when
I was just about ready to swap in a mini CP3 into it too before this VW emissions thing came along
coker6365
Dec 4, 2011
486
I agree, way too many variables associated. Ford utilizes a single lift pump that supplies +55psi to function properly.
Build a mount and just throw an LBZ on it with a belt drive. Fuel for days! :roflmao:
2,207
The mini CP3 can supply more fuel then the original CP4.1 that comes in it. And only takes a small bracket that is made from a flat plate mounts right in the same location
images
coker6365
Dec 4, 2011
486
images
Nice, looks like a very simple swap.
Sent from my SM-G930V using Tapatalk
coker6365
Dec 4, 2011
486
I'll sell you one of my NIB ones for $175 shipped
Donations only, lol. I just picked up a brand new one for $150. What I really want is a +2015 Ford CP4 to compare. It is suppose to flow about 9% more than the original.
coker6365
Dec 4, 2011
486
Does the Ford CP4 have the gear pump on the back? I have a CP4.2 without the gear pump that I have no use for
See here: http://forums.tdiclub.com/showthread.php?t=387252
The Ford pumps do not have a gear pump, the regulator is relocated, FCA is ofset 90 degrees, and the suction/return is an oring fitting rather than hose clamps.
I have a good 2011-2014 Ford pump, would really like to snag a 15+ to see what they changed for the increased flow.
coker6365
Dec 4, 2011
486
Why do the Ford pumps not fail??
The Ford pumps fail too, just not as often. I would guess it is due to the factory lift pump design rather than relying on a mechanical pump to pull a vacuum over such a long distance.
