The engine builder wanted me to do the rod's, I'm considering the option but $2k more for carillo's I'm starting to have engine heart burn. Oh well its only money
Like said its not more if you take away things you really do not need.
I agree with everyone here. If money were limited the FIRST thing that I would do is the rods. We have bent, broken, and put rods through an LLY block with stock headbolts without ever blowing a gasket. Build a solid bottom end first with the money you have to work with, then start adding the more optional things like head work, cam, turbo, injectors, ect. - all of those things can be added relatively cheap after the motor is in without needing to be rebalanced.
I wanted the stock rods not my builder, he recommended Carillo's and I didn't want to spend the money.
Since posting my questions, I have had a change of heart and ordered up carillo's now, again it's only money.:thumb:
You'll be glad you did rods. The peace of mind will be worth more than the money spent. Now you can throw what you want at the engine and feel pretty comfortable with it.I wanted the stock rods not my builder, he recommended Carillo's and I didn't want to spend the money.
The upper oil pan,next to the starter.
Why not tape and drill the block? It's already at the machine shop it wouldn't take much to do right now. I just need to know were on the block???
to update this ARP now has rod bolts available,, 230-6301. I've got a set coming to try out in my build. they give specs in stretch and ft lbs. I'll be using the stretch method.
Not that you can everytime, but stretch method is always the best spec to go by. Followed by angle than torque
Sent from my PC36100 using Tapatalk
