LLY: LLY Rod Bolts
othrgrl
Diesel Addiction Owner
Mar 10, 2008
2,151
Wilmington NC
www.mydieseladdiction.com
I agree with everyone here. If money were limited the FIRST thing that I would do is the rods. We have bent, broken, and put rods through an LLY block with stock headbolts without ever blowing a gasket. Build a solid bottom end first with the money you have to work with, then start adding the more optional things like head work, cam, turbo, injectors, ect. - all of those things can be added relatively cheap after the motor is in without needing to be rebalanced.
coldLBZ
Apr 22, 2007
2,344
Alberta, Canada
X2
Who is doing the work?
rebel7777
Diesel Head
Jan 15, 2010
97
Sherwood Park, AB Canada
I wanted the stock rods not my builder, he recommended Carillo's and I didn't want to spend the money.
Since posting my questions, I have had a change of heart and ordered up carillo's now, again it's only money.:thumb:
coker6303
Keep Calm and Chive On!!
Aug 6, 2009
2,484
40
Houston, TX
It's just money...they print it everyday!!
08 LMM Chevy CCSB
Relentless Diesel trans
JoshH EfiLive tuning
554hp 1014ft-lbs 7/30/11
LWATSON
future trans limpers
Jul 30, 2008
2,587
55
Scotland Neck NC
You'll be glad you did rods. The peace of mind will be worth more than the money spent. Now you can throw what you want at the engine and feel pretty comfortable with it.
rebel7777
Diesel Head
Jan 15, 2010
97
The block has the ability to take threads better than the pan, I would have to utilize a bulk head style fitting on the pan, I would rathar do the block. Makes it even easier for working on the engine if I have to remove the pan later for any reason. You can't tell me there isn't a place on the block to tap and thread??? I dont always want the easy way out, help me guys ;)
madmatt
Apr 12, 2009
1,595
"the mecca"
www.facebook.com
you're thinking the oil drain fitting through WAY to much. it's a drain fitting,, why in the hell would you wanna punch holes in a good block if there was no advantage to it?? weld the fitting in if you're worried about using a bulkhead or threaded fitting. and really to drop the pan it would be one more hose to disconnect,, if you're worried about that you'll despise working on a twined truck,,,
madmatt
Apr 12, 2009
1,595
"the mecca"
www.facebook.com
to update this ARP now has rod bolts available,, 230-6301. I've got a set coming to try out in my build. they give specs in stretch and ft lbs. I'll be using the stretch method.
x MadMAX DIESEL
<<<< No Horsepower
Dec 30, 2008
7,535
Lexington, Ky
Not that you can everytime, but stretch method is always the best spec to go by. Followed by angle than torque
Sent from my PC36100 using Tapatalk
