LLY mods for LBZ airbox?
cstephens93
Oct 13, 2014
677
31
Tallahassee, FL
That may be what I try next. Here are some pics of my setup with the airbox in place . may be hard to see because of the sun glare uploadfromtaptalk1427994293651.jpguploadfromtaptalk1427994342077.jpg. The white spot in the second pic is actually the light shining though my fender well
cstephens93
Oct 13, 2014
677
31
Tallahassee, FL
If you read the past posts, you'll see where other people have also cut it out. But I dont think any of them suffer from lack of air or a stuffed up filter
testdrive
The idea is to draw cool from the fender and front, and not allow hot air from under the hood. Helps to keep the intake air temps down. After I did the mod that C20 has shown, my filter minder remains in the default position. As Ferm mentioned you might open up the front behind the headlight, can't hurt anything.
I am not happy about what I see in your pictures... What have you done to your air filter box?
zf>allison
you never had your car.
Apr 30, 2013
3,394
elsberry mo
picture.php
Did my box tonight. Got a little crazy this is an 05 lly. Cut the front mount off to lol still has 2 more.
cstephens93
Oct 13, 2014
677
31
Tallahassee, FL
I dont exactly know what Ferm means from behind the headlight w/o some pics.
My airbox is an LMM airbox with the MAF sensor port fashioned to fit an LLY/LBZ MAF. Today I did the PPE mod in addition to opening up the fender well like C20 said.
THEFERMANATOR
LEGALLY INSANE
Feb 16, 2009
3,890
ZEPHYRHILLS, FL
With the PPE mod, there is no need to open up your fender opening. I personally do not like cutting the airbox like yours as I don't want it to be sucking in hot underhood air, I prefer it to only be able to pull in cool fresh air.
cstephens93
Oct 13, 2014
677
31
Tallahassee, FL
Yeah well honestly, you can just pull the blade like thing out and put it back in, the only part I cut was about 3-4 inches of it where it sits behind the headlight
I guess if all else fails, I could always buy an S&B LBZ intake, but thats about 260 bucks. I only spent 80 on the airbox in addition to an hour or so cutting and scratching my head as to why my filter minder keeps showing red.
It all comes down to me worrying about my truck not running optimally which is synonymous with "slow" in my head.
zf>allison
Apr 30, 2013
3,394
elsberry mo
Yeah I get what ur saying. I wouldn't imagine it would get an insane amount of heat doing that, there's still air coming through all around the light assembly, but it is closer to the stack. A real world hp comparison of the two mods might not even show up on a dyno. And the box is easier to cut up and replace if I f it up lol.
cstephens93
Oct 13, 2014
677
31
Tallahassee, FL
Ferm, where did you drill the holes at? I uploaded two pics, but i dont see where drilling holes behind the headlight would help
THEFERMANATOR
LEGALLY INSANE
Feb 16, 2009
3,890
ZEPHYRHILLS, FL
GMC's must be different. Yours is open behind the headlight whereas the GMC's are closed. That must be why the TSB to do the airbox upgrade is different for a GMC than a CHEVY.
