LLY/LBZ Mouthpiece with Twins Over Stock Turbo
TRUBBS
461
so, ive looked and looked and looked again but cant seam to find where anyone is mentioning it. what is everyone doing when building/running twins as far as conecting to the stock turbo?
I'm looking to do trans oil cooler and twins on my LLY this spring to make it better for toying my 42' toyhauler and trying to get all my ducks in a row as i will be building the kit myself using a gt45 turbo as the big one
blk smoke lb7
<-----Lots of green $
Nov 8, 2010
5,694
57
belvidere,ill
Your stocker has the lip for the vband all you have to do is get the vband stuband build a charge pipe over to your big charger output.
emiller3
He's Back
Feb 21, 2009
3,586
42
lake charles,LA.
If I'm understanding this you would have to either build a mouth piece like mentioned above or get something like an afe blade runner and close off the additional holes for the PVC crap. You can not use the factory mouthpiece because it will leak once under pressure.
blk smoke lb7
Nov 8, 2010
5,694
57
belvidere,ill
Trubbs if you need an afe mouth piece with the ports welded shut i have 1 for sale.
Noreaster
2,910
Cape Cod,MA
i meant 42 not 45
1.15 ar with 82mm wheel
should be simialar to k31
still think its to small in a dmax set up?
even smaller
atleast need a T6 housing
k31 is 71mm
you don't see much of mid size garretts as primaries with small turbine wheels that are suited for singles or on gas engines. BWs offer larger turbines & are half the cost
S&B makes a nice mouthpiece with one threaded port & outflows the others
TRUBBS
461
even smaller
k31 is 71mm
mine already has a t6 wastegated housing on it, i picked it up and ran in on my 12v fummins over a stocker and just hung onto it after i sold it planning on re-using it on a dmax
but damn sounds like i need to find a s475 or maybe even an 80 :eek:
TRUBBS
461
anyone got a link or measurments on what vband i need to get to go to my stocker?
also- what size turbine wheel should i be looking for?
Operator1
477
NC
I wouldn't be scared to use that gt42, my S475 works just fine with an 83mm turbine and an external gate. MPI probably made more than one of these kits.
fatboylmm
54
I have some custom flanges for that exact application to build the charge pipe they work perfect 65.00 plus shipping
Burn Down
Sep 14, 2008
7,092
Boise Idaho
You mean this?
Big to little charge pipe is on the left & the flange your asking about is facing you. I had a friend copy the plastic mouth piece and cut me a flange with a o-ring groove. Sounds like fatboylmm has what you need better hit him up.
Burn Down
Sep 14, 2008
7,092
Boise Idaho
GT4202 is perfect for towing (Ultra fast spooling) and a GT4508 is good as well. I wouldn't run a smaller 4294 or the smaller 45 versions... S475 and S480 are a good choice as well and are cheaper than the Garrett's.
TRUBBS
461
based on these to inputs, i will try out the 42 i can always change it later on anyways.
should i run the gate? i curently have it tack welded shut as the wastegate actuator was busted up when i got it but i could always make a spring style gate acuator for it.
Burn Down
Sep 14, 2008
7,092
Boise Idaho
1.15 is a touch tight... I would try it the way you have it, but you might have to gate it to control overall boost. I have my gate completely shut on my Comp turbo and Im pulling about 26 psi out of it on my big tune, It's a 1.0 housing.
TRUBBS
461
well i think a gate should be easy enough to make work. so ill go that route.
just need to do some digging to see what spring i need to find. tunning it in might be a PITA
