Lly Lbz differences
x MadMAX DIESEL
<<<< No Horsepower
Dec 30, 2008
7,535
Lexington, Ky
I've got a totally built motor now with 60 overs so that tune won't work I don't guess. I might try and run the lastest tune I have from hims boost control tables.
Sent from my PC36100 using Tapatalk
TrentNell
Finally underway !!!!!
Jul 7, 2008
7,543
slc tuah
Weird, think one of them would be able to do what you want
Its a little harder than you would think , the vain position doesn't reference MPH only RPM , so what ever we try in the lower gears to make the boost higher it has to be kosher in the higher gears as well , so you kinda have to ride a thin line and find a balance between the 2 , I have tuned several LBZ's and this turbo def acts different , with as much fuel as Ben has it shouldn't take near that much vain position to make boost . I will make as many changes as you want to try Ben and you have been very good to work with .
13,752
822
Josh do I need to rescale it? My map stops at 37 right now and my baro pressure around here is 14.7 I believe... Not totally sure what it is in central Kentucky though.
You need to log "Turbo Boost 2" instead of MAP.
x MadMAX DIESEL
<<<< No Horsepower
Dec 30, 2008
7,535
Lexington, Ky
I'll start logging that aswell as desired boost, and vane Target. I never knew about that pid. Should be interesting now what a run looks like on the computer without trying to remember what the boost was at a certain mph.
