Lly injector balance rates.
6,013
With it varying so much and you not having done that, I would start there. You may have bad connections
Henry95
283
I really should. Will look for a right up and do it adapter.
Burn Down
Sep 14, 2008
7,092
Boise Idaho
I'm with James, way to erratic... Ice pick and ck the wiring at the ficm, It likes to rub through at the top where it is zip tied to the ficm mounting bracket. Although I would think you would get codes if it was the wiring at the ficm but it can't hurt to ck it.
THEFERMANATOR
LEGALLY INSANE
Feb 16, 2009
3,890
ZEPHYRHILLS, FL
What's main injection rate?
The amount of fuel the engine is getting. The ECM takes the amount of fuel each injector is injecting, and averages it to give you the injection fuel amount or fuel rate. Some scanners will add in pilot while others will show it seperately. Balance rates are just how far +/- each injector is injecting from the fuel rate. So if all 8 injectors are injecting extra fuel from equal wear, your balance rates can still look great, but the fuel rate will be low. Ideally you should see around 8-9 mm3 of fuel at a hot idle with no other loads.
C.bowles2
2005 lly duramax
Nov 16, 2013
489
Ohio
Awesome thanks a ton that totally cleared everything up. I have a tech 2 at my disposal so im gonna check mine out.
