If anyone wants to preorder some capacitors to have when you decide to have them replaced, there are three 470uf - 14volt electrolytic, and two 330 uf - 63volt ones. Id stick with a good known manufacturer like one of these:
Rubycon
United Chemi-Con (or Nippon Chemi-Con)
Nichicon
Sanyo/Suncon
Panasonic
Hitachi
The OEM ones are Vishay / BC Components which I don't know the quality of. They are 125c rated. Higher temperature rating is good. And higher voltage rating on replacements won't hurt but can increase their tolerance for voltage spikes, also good. I wouldn't mess around with the capacitance values, especially the 330uf ones as I believe those are the ones that drive the injectors and higher or lower capacitance may change the injector lag causing all sorts of tuning or fueling issues
Also, if you have multiple to choose from when shopping around, choose the ones with the lowest ESR or impedance that you can. But also keep in mind the dimensions. Stock ones, 470uf look to be 21 mm tall by 11 or 12 mm in diameter. The 330ufs are the same height at 21 mm but 18 mm wide. There is enough room to go about 2 mm taller before hitting the case and maybe 1 mm diameter in width
Once again
3x capacitors at 470uf, 14 volts or more, 23 mm or less in height, 12 mm or less in diameter, 5 mm lead spacing, 125° or higher operating temperature
2x at 330uf, 63 volts or more, 23 mm or less in height, 19 mm or less in diameter, 7.5 mm lead spacing, 125° or higher operating temperature
