LLY Ficm
kidturbo
Piston Tester
Jul 21, 2010
2,552
1,401
Somewhere On The Ohio
www.marinemods.us
No the Isuzu ficm needs ground fixed. Any ideas on that?
On the tcm's, just found a connector.. Will at least pull data and see if they talk.
kidturbo
Piston Tester
Jul 21, 2010
2,552
1,401
www.marinemods.us
How valuable is a LB7 "medium duty" chassis and engine harness before I hack this one up? It's had one of the control wires between the ECM and FICM replaced somewhere along it's life.
Also did the LB7 have VATS? Hope I don't need to burn a licese to disable it in this medium duty ECM.
2,239
Don't know about the medium duty but my LB7 had VATs
  • Sad
Reactions: kidturbo
1,148
I wouldn't think it's that valuable but I didn't expect some of the used prices I have been seeing on some of this stuff either...
What's the alternative?
1,148
Still searching for someone local with a running LB7 I can test that crank signal on.
For a quick bench setup, only need the ecm and ficm connectors. And a ecm with vats disabled.
Just curious, I know your trying to shorten things up and simplify them. Does the other stuff not being used effect what your trying to do? Does it mess thing up electrically?
kidturbo
Piston Tester
Jul 21, 2010
2,552
1,401
www.marinemods.us
With a few potentiometers on primary sensors, an apps, and some injector solenoid or resistors wired in, I've found they have no idea the rotating parts are missing.
Ya basically wire everything up, power the correct pins, and then adjust the sensor values using a scan tool. Then once ya add the crank/cam emulator signals, everything fires right up. Minus all the smoke, noise, and spinning fan blade..
1,148
So basically you have to cut the plugs off to hook up the potentiometers to act as sensors.
2,239
Have you looked at his twin boat thread? He did a similar setup for an LMM. It's basically fooling all the inputs to the ECM to make it think all the sensors are within range. Potentiometers are the easiest to use. Interestingly the ECM's appear to be happy accepting either a frequency based signal for the MAF like it does in stock form or just a variable voltage. So a simple resistor will give whatever airflow you want. If I'm not mistaken, everything else, ECT, fuel pressure, fuel temp, oil pressure, etc all use variable voltage so a simple potentiometer will work to replace any of those sensors.
Injectors are harder to trick. I did it before with an inductor as I couldn't find any resistors that would keep it out of limp mode. Had to try a handful of inductors before I found one that it liked. I think Ken just uses the actual coils from the injectors to keep it happy. Same for the fuel regulator
1,148
Yes I have seen it. I am not an LB7 guy so to me the harness being cut up doesn't hurt my feelings. But other's might disagree.
Unfortunately with out a physical truck to get the data, his bench set up is the next best thing.
Looking at the prices of what some of these knuckle heads want for used stuff, I can see why he asked first.
Reactions: 2004LB7
PureHybrid
Isuzu Shakes IT
Feb 15, 2012
3,517
501
Central OH
The only parts he needs local is the ECM, FICM and your injector solenoids. You can package them up and Tom can make then be local to Ken 😁
Probably less time consuming to just send the whole truck!
I don't personally know anyone that has a scope, but if there's a member in the Zanesville area I'll have the truck until Friday at least
Reactions: 2004LB7
kidturbo
Piston Tester
Jul 21, 2010
2,552
1,401
www.marinemods.us
Also spoke to Andrew with the OG PPE boat last weekend. Since it's already in a box, and needs some medical attention, he's gonna ship me the first LLY stand alone harness hack job I ever did.
The medium duty LB7 harness I have is complete minus injector harness sections. To me it's scraps, but moment I chop it up, someone bound to say they'd gave me $1000 for it complete... lol
darkness
1,329
393
vegas
Verified no VATS. pic from the stock file. Hell, the medium duties don’t even have a bcm so…
Reactions: kidturbo
