Lightweight thread....
SSchmi5519
LLY Cult Leader
Oct 19, 2008
3,387
Arizona
The tailgate was a lot lighter than i thought it would be. I remember the tailgate in my old Titan was a lot heavier than the one on this silverado.
JMK777
16's, but i keep em clean
Mar 20, 2008
1,433
5
Moss Beach
Get out a cutting wheel and go to town. Back half the truck behind the leafs or go to a 4 link and cut it up to the axle . Cut out cross members and build them out or lighter material, just keep the outer skin of all body work cut out the inner except where needed for mounting
1,954
I have gotten my truck down to ~6450lbs with me in it at the track. It normally weighs somewhere around 7100lbs, full tank of fuel, me in it.
This is what I do for weight reduction (all weights are approximate)
Tailgate: 70lbs
Spare: 80lbs
Spare winch: 20lbs
Hitch: 50lbs
Tonneau: 30lbs
Rear Seat: 150lbs
Pass Seat: 90lbs
Jack/Tools: 20lbs
2nd Battery: 50lbs
1/2 tank of fuel: 90lbs (7lbs per gallon)
It usually takes me about 1/2 hour to prep the truck at the track. I take the rear seat out at home unless the kids come with me.
I also removed the overload springs, but adding the Caltracs, pinion snubber and computer stand for EFI offsets that.
I could still remove the rear bumper (70lbs) if I wanted to or if I am close to my goals.
And yes, its 200lbs per .10 for our trucks. IMO, its foolish not to take advantage of "free" hp.
TeaBagger2006
Im a Garrett Nut Swinger
May 11, 2008
3,123
15
Bis ND
i could of had a 13sec button if id known about all this secret stuff...too embarrassed to ask fo my 14 sec one...i ran a 14.1/slow:(
Redbowties88
Sideways > Straight ;)
Aug 24, 2009
1,943
609 New Jersey
Ec/lb are lighter then crew cabs by a decent amount.
I never realized the whole backseat weighed 150lbs seems like theirs not much to it. I figure ontop of your list I can loose another 50 by going to 2 front sport buckets. I would Also really like to loose the hood that thing is stupid heavy
Akdiesel
IFS Hater
Aug 23, 2009
2,213
Fairbanks
Wish I had an ECLB gotta take my pig to the scales sometime and see what she weighs. But I'm hoping alot cause my times are slow haha
sweetdiesel
That's better
Aug 6, 2006
10,390
Thailand
dont forget the antenna
That's actually a common thing to remove if your a racer
you have to think like a dope dealer and that every ounce counts!
Eric care to share what all your doing to get yours down that low?
I wish more people would of been into getting a glass bed that was plug and play
hondarider552
Getting faster
May 28, 2008
10,627
Arizona
My fuel tank is a 5 gallon gas can in the passenger floor. saves 250 lbs and it works. My TTS pumps are also zip tied to the side of the gas can. works for me. :D
JMK777
Mar 20, 2008
1,433
5
Moss Beach
lighten rotating mass. you can remove 16 lug nuts you might be able to get away with 4 per wheel :hehe:
