LB7: Lift Pump Experience??
jd4230
Jan 7, 2013
5
I've been thinking about an Air Dog II 165. Has anyone had any experience with that lift pump and how it reacts when your fuel tank is below a 1/4 tank? I don't want to start sucking air. I know this lift pump is an air separator also, but if it starts sucking air at low fuel levels, I would think that would shorten its life.
S Phinney
4,008
Quncy, Fl
I have it on three different trucks myself. They work just fine. No low fuel issues what so ever.
Andrewslmm7
Feb 27, 2013
Ct
Figures I got a banging deal on a 95 back when the truck was stock so what's the best way to go about upgrading sence I plan on big injectors and dual pumps? Just get a bigger lift pump?
TROJAN366
Gold Rush
Jan 13, 2012
2,474
MASS
What are people's opinions on running a raptor or kennedy pump in conjunction with the Fass 95? Should up the volume and retain the Fass filters. Or am I way off base here?
sweetdiesel
That's better
Aug 6, 2006
10,390
Thailand
most people that run twin lift pumps run them side by side. One kennedy pump is 3-4 psi
DMAXchris
It’s only temporary!
Apr 28, 2009
2,273
Natrona Heights PA
They fixed the 1/4 tank issue a couple years ago. The AD-II uses the factory pickup. No need to drop the tank for a draw straw anymore. There wasn't even a real problem, people were cutting the pickup line too short.
duel Kennedy pumps maybe?
Depends on how big your aquarium is.
ctrump90
ctrump90
Jan 11, 2012
471
Clare, IL
My truck sucks air after quarter tank..... and dies. I have a raptor 150... on factpry lines.... anyoneexplain that?
Sent from my SAMSUNG-SGH-I747 using Tapatalk 2
TROJAN366
Gold Rush
Jan 13, 2012
2,474
MASS
I guess I've gotten lucky. I run my truck at the track with 1/4 or less and never have an issue. One night leaving I couldn't find diesel and had the gauge reading below empty before I found an open station with diesel.
DMAXchris
Apr 28, 2009
2,273
Natrona Heights PA
That's odd. I'm running an AD-200 and have had it down well below the light. You might have to pull out the sending unit and see whats wrong.
blk smoke lb7
<-----Lots of green $
Nov 8, 2010
5,694
57
belvidere,ill
They fixed the 1/4 tank issue a couple years ago. The AD-II uses the factory pickup. No need to drop the tank for a draw straw anymore. There wasn't even a real problem, people were cutting the pickup line to short..
I run the draw straw and I could run the ppe hot+2 on level 10 with the draw straw in.Couldnt do that witout the draw straw.It does help with flow.I think ctrump90s problem is the draw straw has a crack or is broken off
