That is interesting. The rod and main journals are the same dimensions? Lml Pistons and rods not required?Cranks are interchangeable.
pretty sure josh is saying the crank will go in an older block but you still have to run a L5P rod. the L5P crank has .200 larger dia rod journals over 16 and older cranks. hence why they are far stronger than previous yearsThat is interesting. The rod and main journals are the same dimensions? Lml Pistons and rods not required?
If that's the case. Someone needs to do, l5p crank, rods and somehow slap some lb7 pistons on it and see what it can handle lol. Would be neat, alot of wasted time though I'm sure.pretty sure josh is saying the crank will go in an older block but you still have to run a L5P rod. the L5P crank has .200 larger dia rod journals over 16 and older cranks. hence why they are far stronger than previous years
I should have been more accurate with my statement. The L5P crank and earlier Duramax cranks will interchange between blocks. The rod journal on an L5P crank is bigger than the others, so the rods are going to be crank specific and have to match the piston and block they are going in. In other words, you can't just slap an L5P crank in an earlier block or vice versa without getting custom rods and/or pistons, but the crank will swap between blocks. That's all I meant when I said they are interchangeable.That is interesting. The rod and main journals are the same dimensions? Lml Pistons and rods not required?
IIRC they will, you just dont use two of the tiny 8mm head bolts the L5P uses. also, pistons are still weak in them.Do earlier model heads go on an l5p shortblock? Im sure they dont but..... sure would be sweet if they did. I was looking at a not far from new l5p motor that came out of a wrecked truck but didn't think it would work.
Like James said, you can bolt the heads on, but the taller deck height means just about everything in the valley will have to be custom (the biggest issue is high pressure fuel lines from CP3 to rail and rail to rail). The other issue will be oil pump/front cover/oil pan issues and reluctor wheel. The earlier reluctor wheel will slide on the crank, but there is no line up dowel from the factory on the L5P crank. It would take a LOT of work to make the L5P short block work with all the earlier Duramax parts, but it has been done.Do earlier model heads go on an l5p shortblock? Im sure they dont but..... sure would be sweet if they did. I was looking at a not far from new l5p motor that came out of a wrecked truck but didn't think it would work.
That's something we are working on trying right now.sounds like it would be easier to just use an L5P long block with LBZ or LMM electronics
That would be an interesting thread Josh. I have been thinking that would be fun to do with my truck someday but depending how hard it is it ma never happen.That's something we are working on trying right now.
So, we are a long way from driving the truck and figuring out all the little tuning quirks, but we fired up our L5P on LBZ electronics last week. It idles well and seems to rev pretty cleanly. The truck doesn't have any driveshafts yet, and brakes need to be hooked up and bled. Hopefully it will be driving by the end of the year. S&S is supposed to have the 200% injectors done and headed our way this week.That's something we are working on trying right now.
Welcome, you might want to start a new thread for this. You will probably get better response without messing up this one with a lot of unrelated informationBringing this old thread back from the dead a little. last post was almost a year ago. I am researching what is necessary to fix my 2007 Kodiak 5500 with LLY/LBZ. it has a gnarly rattle/knock that seems to lessen when rpms increase. I am (in my own non diesel guy head) convinced that the noise is a failed wrist pin bushing. I dunno what engine it truly is, LLY or LBZ. the info in this thread has been a good read. i am thinking i might get away with a new bushing or maybe a single piston and rod.
I am also hoping there is an update to the L5P on LBZ electronics update. any update?
thanks for the info.
